Old 09-30-2013, 01:32 PM   #1
Midgets50
Midgets50's Avatar
stock axles on 79 4x4
Does anyone know what stock axles would be from my 79 k2500 gm truck. I've heard D60 rear and ad 44 front but have no clue. Any help would be greatly appreciated
Midgets50 is offline   Reply With Quote
Old 09-30-2013, 01:41 PM   #2
crashz
crashz's Avatar
Re: stock axles on 79 4x4
Most likely a Dana 44 front axle and GM Corporate 14 bolt (full floater) in the rear. Keep in mind that there are different version of each (brakes and hubs usually).
2012 Chevy 2500HD, 6.0L, 6spd auto, 4x4, ECSB
1987 GMC V3500 Dump, 6.2L diesel, TH400
1983 GMC K2500 - awaiting its restoration and Cummins swap.
crashz is offline   Reply With Quote
Old 09-30-2013, 01:49 PM   #3
1981Sturgis
1981Sturgis's Avatar
My 79 3/4 ton 4x4 had Corp 10 bolt front, and corp 14 bolt rear.
1981Sturgis is offline   Reply With Quote
Old 09-30-2013, 08:28 PM   #4
Midgets50
Midgets50's Avatar
Thanks for the input guys. im pretty sure my rear diff cover has 14 bolts. how stout are these axles? The previous owner ran a HD snowplow on the donor truck. im planning on running 33's with a 4bt cummins. Should i invest in stronger axles or will these do the trick if i plan on have it has a daily pavement driver that might see occasional mud. If not what would you guys suggest and with what gearing. As always thanks for the help guys. such a wealth of knowledge on these forums
Old 09-30-2013, 08:59 PM   #5
LONGHAIR
10 bolt for sure by '79. Dana44 was phased out in the '77-'78 models.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 09-30-2013, 09:43 PM   #6
russgt
russgt's Avatar
I pulled a dana 44 out of my grandpas 80 k20. 61k original miles on an all stock truck.
You will be fine in your application with either a 10 bolt or dana 44 in the front. The 14 bolt is a very strong axle.
70 stepside
76 blazer
86 Silverado
20 Max Trailering 6.2 Crew
71 Nova SS
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634
russgt is offline   Reply With Quote
Old 10-01-2013, 12:04 AM   #7
mrolds88
My 80 K10 had a 44 in it too. I think they ay have used the 44's in the MT trucks and the 10 bolts in the auto trucks. My 79 Blazer has a 10 bolt in the front .
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 10-01-2013, 07:56 PM   #8
russgt
russgt's Avatar
This 80 was an auto truck with the odd ratio of 3.21
70 stepside
76 blazer
86 Silverado
71 Nova SS
Old 10-01-2013, 01:29 PM   #9
wilkin250r
wilkin250r's Avatar
My 79 3/4ton has the D44 up front, Corp 14B full floater in the rear.
The D44 or the Corp 10 bolt are similar in strength. There are stronger axles out there, obviously, but either of those front axles will be plenty strong enough to handle 33" tires. I wouldn't say you need to upgrade until you get upwards of 38" tires, and even then it would be fine for pavement and mild offroad use.
As for the Corp 14B rear, there AREN'T a lot of stronger axles out there, that guy will take any abuse you can throw at it.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!!
wilkin250r is offline   Reply With Quote
Old 10-01-2013, 09:50 PM   #10
willett
Another Day, Another Dollar
willett's Avatar
The 14 bolt is a sh*t kicker. Comparable to a 60.
If you have a 3/4 ton you likely have a 44hd up front. It has tougher axle shafts than a reg 10 bolt or 44, but if you are going to run your truck hard expect to shred an axle.
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 10-01-2013, 09:52 PM   #11
willett
willett's Avatar
I've seen an unlocked front 44 destroy a driver side axle on 31's. we were partying pretty hard though
Old 10-02-2013, 01:35 AM   #12
andrewmp6
A nice chart to use http://coloradok5.com/axleguide.shtml
