starter and flex 4 700R
I'm getting ready to in stall a 700R in my 66 sub it has a 327 in it need to buy flex plate and starter what year to buy. Thank you
Re: starter and flex 4 700R
My install was not a sub but its all the same... Best prices would be at Summit: Chevy flex plate 168 teeth (SUM-G100SFI) Universal Hitachi starter (SUM-829100). Works great with no issues...
CURRENT & PAST CHEVY TRUCKS 60 C-10 Apache short step side 62 C-10 short step side 66 GMC Long bed fleet side 305 V-6 77 C-20 Custom Deluxe (Blue Goose) |
60-66 Nut
I don't have much experience with the 700R4's, but I do believe all you need is an '85 and earlier 14" 168 tooth flexplate for an internally balanced small block. Then you will just need the correct starter for the 168 tooth flexplate, which will have the staggered bolts. Essentially these would be the same parts used for a TH350. The starter doobiebro linked to has the straight bolt pattern, but is drilled to work with either the 153 tooth flexplate or the 168 tooth.
