Please give me your opinion....51 3600 build
Quick and brief history of my build:
Started with an original '51 3600 stake body. Bought a '52 3800 with the xtra long bed. Shortened the extra long bed to around 7' and installed on the 3600 cab / frame per factory dim's. I have had 3 comments from 3 very good friends that when I ask them for honest opinions, they give me honest opinions. All 3 say that my rear wheel is not centered in the rear fender. I have studied about 25 online pics of 3600's and do notice that the wheels appear to be somewhat forward of the rear fender centerline, if there is such a dimension. Below is a pic of my build in process. Sorry for the poor quality pics. Whats your opinion?
Mgeez Felton, Pa. My toys: 1951 Chevy Truck 3600, 1952 Chevy Truck 3800, 1954 Case 411B, 1939 Ford 9n, 1972 Kubota B7100 http://s1282.photobucket.com/user/m_geesey/library/ |
![]() Join Date: Dec 2012
Re: Please give me your opinion....51 3600 build
none have wheels centered origionally
1946 car hauler 1948 surburban 1937 chevy sedan 1940 olds sedan (project) 1967 ss396 chevelle 1999 dually crewcab(24000 miles) |
do you plan on lowering it?
The rear wheel does look a bit to far forward in this picture. Your front tire also looks closer to the rear of the front fender rather than being centered.
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
No plans to lower it. The front suspension / fender placement is original. I will try to take a clearer pic tonite. Space is really crammed in the barn right now for a really good pic. I can move the rear fenders forward, but that will require shortening the running boards and the side aprons, again!
If I didn't know that it was a 3600 rather than a 3100 I'd think that you had swapped rear ends and hadn't relocated the hole in the spring pad to center the axle in the wheel well. That is exactly how most of them look when guys bolt the axle down with the hole for the spring bolt directly under the center of the axle rather than drilled the 1-1/2 or 1-3/4 in front of center to move the axle back and center it.
Does the truck have an engine, trans and drive shaft in it now? If you were going to swap engines and transmissions you could conceivably move the axle back to center it in the opening before you built a new drive shaft and none would be the wiser.
Could you maybe move the bed forward. By the pics, there may be some room or you may have to shorten it some more. Just a thought.
Posted via Mobile Device |
#7 | |
Mark
#8 | |
The running board and apron shortening is the cheapest alternative ($0.00) I have right now and time involved for me will be 2 days. I am pretty sure the axle / springs have never been touched since new. I probably measured wrong when I initially located the bed. I appreciate your opinion, though. Mark
Another easy fix I used on my truck was new spring saddles. I picked up a set on EBAY for about $35 that were drilled with an 1 1/2 inch offset.
http://67-72chevytrucks.com/vboard/s...d.php?t=592642 '48 Chev extended cab with attitude http://67-72chevytrucks.com/vboard/s...d.php?t=592769 My daughter's '46 International PU |
Don't know if it would help but what size wheels are you running?
Here's a pic of my stock suspension 3600 and I think yours looks a little further forward maybe. I run 15s. It maybe possible the a rim size change may alter the look a little. Wouldn't solve it totally but there are a few good options already suggested. The angle of the my pic probably makes the rear wheel appear a little further forward than it looks when you are square on. ![]() Posted via Mobile Device Posted via Mobile Device |
#11 | |
My truck, the rear fender touches the front of the rear most stake pocket flange edge. This appears to be the 1 1/2" I am off. I guess I measured something wrong this past spring when I started this swap. I used the original fender mtg holes on the bed side panels. I removed approx 12" from the front and rear of the bed sides. Apparently this is where I was off 1 1/2 inches. I do know my bed is not 100% correct length for a 3600. My first build! I know better the next time! I appreciate you comments and pic. Thanks! Mark
#12 | |
Mark
![]() Join Date: Jun 2013
The 3100 AD trucks did not have the rear axle centered in the fender well either.
Gale Gorman '54 3100 '67 C20 stepside |
These trucks did not come from the factory with the wheels centered in the wheel wells.
![]() 1949 Five Window, 1973 Step Side, 2000 Z71 |
#15 |
I was at the Hershey Swap meet this past weekend and to me, it looked like the 1/2 tons rear wheels were fairly centered in the wheel well. The 3/4 tons all favored the rear wheels to the front of whatever one could call the centerline. I finally moved my rear fenders 1 -1/2" forward just for a better look.
#16 | |
#17 |
Looks to be perfectly centered there, and at the right price too
