Old 10-02-2013, 06:53 PM   #1
Big - T
1974 Chevrolet C-10 Custom (diesel)
Hey everyone, I've a '74 Chevy c10 that I'm restoring and while in the process, I thought why not get another one but convert it to diesel. Like maybe put a Cummins4bt or 6bt in it? However, I wasn't sure if it would hold a 6bt considering the weight and torque that engine produces. So I need y'alls advice/wisdom on it. I'll post some pictures of the '74 I'm currently in the process of restoring for you guys.
Big - T is offline   Reply With Quote
Old 10-02-2013, 06:58 PM   #2
Big - T
Re: 1974 Chevrolet C-10 Custom (diesel)
Paint job looks new, but its actually original. Old guy that owned it kept it in the garage most its life.
Old 10-02-2013, 08:53 PM   #3
motornut
78K & 79C Jimmys
motornut's Avatar
dam that looks good
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 10-02-2013, 07:00 PM   #4
Big - T
original 350 with 97k
Old 10-02-2013, 07:30 PM   #5
Brockwaykid
Brockwaykid's Avatar
You might want to be careful if you go the cummins route with the truck being a half ton. I think a 4BT would be safe but if you went the 12 or 24V route you'd be better off with a 3/4 ton... Just my 0.02$. Very nice looking truck!!!!
Jeff Shaw
2003 Chevy 2500HD LB7 Duramax
Brockwaykid is offline   Reply With Quote
Old 10-02-2013, 07:34 PM   #6
Big - T
I was kinda thinking the same thing. I currently have a 12v at the shop, so that would save me a little cha-ching but then I'd need to invest more into the truck it'll be dropped in so it could support that kind of engine. Or just invest a little less in the actual truck and use the rest for purchasing a 4bt.
Anyone can fly a plane, but only some can pilot a plane.
Old 10-02-2013, 09:04 PM   #7
Big - T
Thanks man, considering the old man did his part in preserving history, i figured I ought to do mine.
Old 10-02-2013, 09:50 PM   #8
flashed
WOW ,that is a nice looking truck ,maybe since we are not that far apart maybe I can see it in person someday.
flashed is offline   Reply With Quote
Old 10-02-2013, 09:53 PM   #9
Big - T
Yeah man, however as of mid-late november it'll be in the shop for a complete rebuild/restoration. So if you'd like to see it before we'd need to make plans before then.
Old 10-03-2013, 12:02 AM   #10
Edahall
To be honest with you, your c10 is plenty strong enough to support a 6BT. I've got a half ton Tahoe with this engine in it and have had no issues with the additional weight. That said, I highly recommend the 6BT over the 4BT. The 4BT's are loud and make enough vibration to loosen teeth fillings.
1990 ¾ ton 4x4 Chevy Suburban
-Cummins Diesel - 12 valve - factory rebuilt
-6 speed bullet proof manual transmission - NV5600
-Gear Vendors Overdrive - HX35 Holset Turbo
-NP205 iron transfer case
-3.73 gears -2" Lift
Edahall is offline   Reply With Quote
Old 10-03-2013, 12:17 AM   #11
Big - T
Interesting, how does it handle the torque? And did you do any reinforcements or anything along those lines to allow it to handle the engine better?
Old 10-03-2013, 03:14 AM   #12
INSIDIOUS '86
INSIDIOUS '86's Avatar
People throwing big blocks and transbrakes in these trucks and pulling the wheels off the ground with the sudden shock and torque of a big block. The 6bt will be fine I'm sure
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 10-03-2013, 08:17 AM   #13
legendman
legendman's Avatar
Check out this section on Diesel conversions
http://67-72chevytrucks.com/vboard/f...play.php?f=240
1999 Chevy K2500 RCLB 350 4L80e
2004 Chevy 3500 C&C Dmax Allison
Originally Posted by smackzed View Post
I put a chevrolet tailgate on my last truck and it started acting like a girl...love me, need me, want me pay attention to me. Took it off and put the GMC back on (fixed the latch) and it went back to being the same old dirty bastard it used to be
legendman is offline   Reply With Quote
Old 10-03-2013, 11:45 AM   #14
Big - T
I see your point there. Also, did you have any need to move the firewall back or any reworking of the engine well to allow it to fit the 6bt?
Old 10-03-2013, 12:18 PM   #15
Edahall
No reinforcements were needed other than adding a crossmember. Remember, the frame on these trucks are stronger than the Dodge trucks these engines came out of. It handles the torque just fine. However, I never goose my trucks. I just drive them normally and only use the power as needed. I've also never had any issues with the 1/2 axles but I don't drive off road.
The engine bays on these trucks are more than adequate to fit a 6BT. In fact, when all is said and done, the engine looks like it was meant to fit in there.
Old 10-03-2013, 12:21 PM   #16
Big - T
Gotcha. My main purpose for doing this is so I'll be able to haul heavy loads of metal and equipment that the 350 couldn't. Which is were that extra torque helps out!
Old 10-03-2013, 02:21 PM   #17
legendman
legendman's Avatar
x2
Also check here for some more swap info
http://www.4btswaps.com/forum/forumd....9-Conversions
Old 10-03-2013, 06:14 PM   #18
Big - T
What about turbos? Like brand, model, etc? And I'm assuming it'd be a good idea to possibly put a "heavy duty" rear end in it.
Old 10-03-2013, 11:54 PM   #19
Zane M
I think it is cool what you are planning to do.
But I will throw out this: If you plan on hauling loads "the 350 couldn't", your existing half ton suspension/brakes probably can't either.
Zane M is offline   Reply With Quote
Old 10-04-2013, 09:18 AM   #20
Corts60
Just here to tinker
Corts60's Avatar
Definitely following this thread as I also plan on putting a 6bt in my '78 shortbox.
1974 custom, 350, c10, chevrolet, restoration
