10-03-2013, 03:19 PM | #1 |
Power vs Manual intermediate shaft
I’m converting from manual steering to power and would like to know if the intermediate shaft is the same or do I need to get one from a power truck. My new power steering box has a 13/16” shaft and that made me start thinking, the manual box had a ¾” shaft and they may be different.
I’m still looking for a new rag joint so I can’t mock things up until all the parts have been located.
"God will often give you more than you can handle so you can learn to depend on him rather than on yourself" ...Craig Groeschel |
10-03-2013, 05:13 PM | #2 |
Re: Power vs Manual intermediate shaft
When I converted my '69 to power (from a '75), I just dropped it in (with pitman arm attached) without changing anything.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
10-03-2013, 06:40 PM | #3 |
The splines on the man are 3/4 x 32 so you will need the bottom section of the joint they ca n be found on line and at most parts stores in the help section
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
