Old 10-06-2013, 04:47 PM   #1
rideblue00
rideblue00's Avatar
Wiper arm spline replac?
Anyone replace the splines on their arms? Mine are toast! I looked in the FAQ, but didnt see anything on that. Any info would be appre.
rideblue00 is offline   Reply With Quote
Old 01-04-2014, 05:06 PM   #2
rideblue00
rideblue00's Avatar
Re: Wiper arm spline replac?
Bump
Old 01-04-2014, 05:21 PM   #3
rideblue00
rideblue00's Avatar
Has anyone bought the reproduction replacement parts?
Old 01-04-2014, 05:33 PM   #4
rideblue00
rideblue00's Avatar
maybe i should clarify: I'm talking about the part that the arms slide on to. those are the splines that are stripped.
Old 01-05-2014, 11:18 AM   #5
Blue666
You can try this or a similar product for blade sets.
http://www.summitracing.com/search/p...-blade-refills
I am not sure what you mean by splines? If you mean the splines in the arm, I think these are cut in & can only be fixed with a replacement arm. TRICO made these also but I'm having trouble finding a web reference.
Blue666
Blue666 is offline   Reply With Quote
Old 01-05-2014, 11:35 AM   #6
Blue666
This arm was used in many applications.
Amazon.com: Trico 73-300 Heavy Duty Adjustable... Amazon.com: Trico 73-300 Heavy Duty Adjustable...
Ebay also has a wide selection of parts.
http://www.ebay.com/sch/sis.html?_nk...d=150134868906
Old 01-05-2014, 12:39 PM   #7
rideblue00
rideblue00's Avatar
Not looking for wiper arms, looking for a new post or a way to repair them.
Old 01-05-2014, 02:02 PM   #8
Blue666
Name:  Wiper pivot post transmission.jpg
Something like this? Wiper Pivot Post, AKA wiper transmission post,
Old 01-05-2014, 01:48 PM   #9
63burban
Chevy addict
They are called trunnions, not real difficult to change the whole assembly as the trunnions are part of the shaft and not replaceable.
Last edited by ETsC10; 01-05-2014 at 09:05 PM. Reason: This is NOT a WTB/FS thread.
63burban is offline   Reply With Quote
Old 01-05-2014, 02:58 PM   #10
61K10
61K10's Avatar
you can buy the whole set-up $99 both sides. have not seen a rebuild kit. post a wtb
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 01-05-2014, 03:01 PM   #11
jayoldschool
Moderator
You can try using some aluminum foil as a shim to take up the space from the stripped splines. Might be enough to give it the required resistance. Easy and free
jayoldschool is offline   Reply With Quote
Old 01-05-2014, 03:26 PM   #12
rideblue00
rideblue00's Avatar
Blue666 that is close, i was hoping to just find the tip with the splines.
Old 01-05-2014, 06:33 PM   #13
Blue666
The first picture was found on Amazon.
This link sells Step & Box van parts but also carries some parts for our type trucks.
http://store.stepvanparts.com/PIVOT-SHAFTS-STEPVAN.HTM
I have not been able to find any replacement knurled knobs so you might have to replace the whole pivot.
Good Luck.
Old 01-05-2014, 07:42 PM   #14
davbowen
davbowen's Avatar
used, they're all over ebay.
http://www.ebay.com/itm/60-61-62-63-...7e848e&vxp=mtr
davbowen is offline   Reply With Quote
Old 01-05-2014, 08:07 PM   #15
rideblue00
rideblue00's Avatar
I have it already out of the truck. And i am a machinist and a welder, so i do ok on repairing stuff. I was planning on just replacing the spline. I just need to find a source for the knurled pc. Newer van ones are larger in diameter. I was hoping to come up with a easy and cheap repair. Spending money on used ones with out seeing the splines is a crapshoot. And the repros are $80-90. So i need some used ones to experiment with.
