Old 10-06-2013, 10:51 PM   #1
rs74
rs74's Avatar
Burb/blazer fuel tank conversion-exhaust?
Okay, I am reading that if you do the burb/blazer fuel tank conversion then you may not have room for over the axle exhaust. Am I right on what I am reading? Does this just pertain to shortbeds? I was thinking about doing this to my rc K30. I want to keep the exhaust out the back behind the wheels and if the tank is going to be an issue then I probably won't do it then. If that is the case are there any other options? Is this for both short and long beds?
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 10-07-2013, 09:46 AM   #2
77ChevySharkBite
77ChevySharkBite's Avatar
Re: Burb/blazer fuel tank conversion-exhaust?
I haven't heard of it. I thought they just fit in that little "pocket" in between the frame rails towards the back half close to the bumper. I don't see why you couldn't still run an exhaust back there unless your wanting to put it straight back then I could see the issue.
Korwin
77 C10 Silverado Sharkbite LWB Build
67 Chevy C10 Frame Off
06 Dodge Magnum 2.7v6 aka swag wag!
2010 Honda Accord 2.4I4 DD aka Liquid Metal
77ChevySharkBite is offline   Reply With Quote
Old 10-07-2013, 10:23 AM   #3
rs74
rs74's Avatar
I will have to go back and find that thread. I read it on here somewhere when I was doing a search on it.
Roy
1987 R10 shortie
Old 10-07-2013, 09:51 AM   #4
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Checkout an installed Blazer/Sub tank on a truck. Captkaos has some nice pictures.
http://www.captkaoscustoms.com/blazertank.html
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 10-07-2013, 10:24 AM   #5
rs74
rs74's Avatar
That is where I read that you might have issues with exhaust. I like my duals to exit right behind the rear tires. I want to be able to put a 90 degree right there.
Roy
1987 R10 shortie
Old 10-07-2013, 09:08 PM   #6
russgt
russgt's Avatar
K5 blazers came from the factory with this tank and were available with dual exhaust that exited behind the wheels, so it will work with a pick up as well.
70 stepside
76 blazer
86 Silverado
20 Max Trailering 6.2 Crew
71 Nova SS
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634
russgt is offline   Reply With Quote
Old 10-07-2013, 09:31 PM   #7
rs74
rs74's Avatar
That was my thought behind the whole thing but just wanted to make sure.
Roy
1987 R10 shortie
Old 10-07-2013, 10:24 PM   #8
jitteryguy
GoatLube Experss
jitteryguy's Avatar
it took some creative bend's but mine come out under the frame rail's on my CCSB.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 10-07-2013, 09:54 AM   #9
77ChevySharkBite
That's slick looking but I mean even with it there wouldn't it be risky to run an exhaust close to whether it's straight out or even angled?
Not trying to high jack by any means but I'm curious to know myself.
Korwin
Old 10-07-2013, 10:05 AM   #10
ghettoluxury
ghettoluxury's Avatar
On a long bed there is plenty of room. There is no issue with running exhaust around the gas tank look. Just look at the old GM cars, they all had the tanks at the rear with the filler behind the license plate and exhaust running right beside it.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
