10-07-2013, 11:47 PM | #1 |
transmission crossmember removal
I have a k10 that I want to spend some time cleaning up, and I was wondering if anyone knew if I can safely remove the transmission/transfer case crossmember with the powertrain still intact. the reason I want to do this is it is caked with gunk that I would like to get cleaned up as well as I can without having to remove the transmission. I also have a jack and jackstands that I could put underneath to support some of the weight.
Austin 2005 GMC Sierra 1500 4X4 4.8l V8 (Wrecked) 2003 Chevy 1500 standard cab short bed 4x4 w/ 5.3l |
10-08-2013, 07:36 AM | #2 |
Re: transmission crossmember removal
If you raise the trans/transfer case high enough to clear the mounts[be a good time to change them] and support them with a jack/jackstand, I see no reason you couldn't remove the crossmember to clean it to your liking. Jim
