Old 10-08-2013, 09:57 AM   #1
i heart square bodys
i heart square bodys's Avatar
rear end questions
okay so i want to put a 12 bolt in my truck. i realize that it is easier to find them with 6 lug pattern but id like to keep the 5 lug. i have a pile of 10 bolt rear ends with 5x5 lug pattern and was wondering if the axles will interchange. also wondering if the brakes will do the same ? now my other thought was to maybe get a 12 bolt with disk brakes but once again the problem arises that i want to keep it 5x5, any way i can do this without having to drill out the rotors (any other oem rotor from other aplication) if i can get the prefered axles in it. thanks !
1986 LWB c10 w/327 & vortec heads
i heart square bodys is offline   Reply With Quote
Old 10-08-2013, 11:46 AM   #2
D13
D13's Avatar
Re: rear end questions
Why a 12 bolt? The truck 12 bolts are not significantly stronger than 10 bolts, actually have smaller pinions.
Axle shafts do not interchange 10 to 12 bolt.
2wd 1/2 tons 73-82 were 5 stud 12 bolts, there are tons of these in the j-yards. 6 bolts in 4wd for 10 or 12 bolts. Need to change U joints and may need metric to SAE brake pipe adaptor to swap complete axles.
Disc brakes are pricey but there are parts available (search this forum and the Suspension forum), costs about the same 10 or 12 bolt. Many kits available, or can piece together with a little thought.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 10-08-2013, 01:27 PM   #3
Sooo id just be wasting my time swappinh from a 10 to a 12? What about going to a 14 bolt ? How easy are they to convert to 5 lug and put my 1/2 ton drums on?
Old 10-08-2013, 01:29 PM   #4
If i swap to a 12 bolt ill get one with the 5 lugs already in it , will the brakes still interchange?
Old 10-08-2013, 02:09 PM   #5
ont_guy_38
ont_guy_38's Avatar
If a bit of width and some fab work doesn't bother you, get a 14 bolt out of a 454 SS truck. They are 5 lug. Unless you have to upgrade gears and stuff anyways, the 12 bolt isn't worth the extra you will spend on it.
1985 C10
2004 Avalanche
ont_guy_38 is offline   Reply With Quote
Old 10-08-2013, 02:25 PM   #6
Well thats the thing , i am going to do a set of gears and posi so i figured id be better off doing the 12 bolt instead of putting my money into the 10
Old 10-08-2013, 02:54 PM   #7
willett
Another Day, Another Dollar
willett's Avatar
I thought that regular 14 bolts (ff) were 8 lug and 14 bolt sf's were 6 lug. Didn't know there was such thing as a 5er
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 10-08-2013, 03:29 PM   #8
The 454ss truck is a 14 bolt 5 lug but thats it , i figured i could get hubs for that application and swap em out
Old 10-08-2013, 04:13 PM   #9
Rich84
Rich84's Avatar
I would just spend the money on the 10 bolt..Plenty of people have them with huge motors.
Rich84 is offline   Reply With Quote
Old 10-08-2013, 04:37 PM   #10
fair nuff !
Old 10-09-2013, 03:03 PM   #11
Keith Seymore
Keith Seymore's Avatar
Agree. I've still got the original 10 bolt in my Chevelle.
555 cu in, 950 HP, 9.80 ETs at 3900 lbs. Been racing this car 35 years, probably 20 of those going 11.80's or quicker.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 10-09-2013, 02:23 PM   #12
ont_guy_38
ont_guy_38's Avatar
Our truck 10 bolts are the same as a car 10 bolt, so parts are interchangeable from any early car 8.5 read end up therefore way easier to get and more reasonably priced. I have a posi out of a camaro in my truck. Works awesome, way better than the Gov lock that trucks have.
1985 C10
2004 Avalanche
Old 10-09-2013, 03:09 PM   #13
Rich84
Rich84's Avatar
I guess mine is safe!!!..lol
Old 10-10-2013, 09:30 PM   #14
lucekfd142
does anybody know if a impala ss rearend will work in a 84 chevrolet truck?
lucekfd142 is offline   Reply With Quote
