WTB; SB clutch linkage
I am doing a I6 to 350 swap. I need clutch linkage from a small block.
Wisconsin, not Canada. |
Active Member
![]() Join Date: Feb 2012
Re: WTB; SB clutch linkage
I have a complete set up from a 68 GMC 327 SM465. Which pieces do you need?
do you have a pic. of parts you need? i was just checking to see what all that is. i should have the parts like clutch rod/z-bar/linkage rods from colum maybe something else. i have all that complete.my parts are for 3 speed on the colum.
i have 67/72 chevy truck parts f/s. |
Here's what I need:
-Arm from pedal to Z bar, has a slight S shape -Z bar -Whatever holds the pivot ball to the engine block -Rod that goes between Z bar and clutch fork |
Active Member
I have it all 35$ shipped
Active Member
Here's a picture, the long rod is 19 7/8 long. If you don't need that it will be a little cheaper as I can get it in a small flat rate box for shipping.
![]() Join Date: Aug 2012
I'm looking for the linkage bar you shown on the far left of your photo. Do you still have it? I'll take it if you do. Just need the linkage bar. Can you post or send photos of the ends. I'm looking for one that is not worn. (My current bar is worn wear it hooks to the pedal arm in the interior.
