10-09-2013, 08:50 AM | #1 |
Help Sourcing a Radiator
I have a 67 GMC 3/4 ton 250 3 speed no air. I've been to Autozone, O reillys, and Culpepper radiator and they are all selling me the same radiator that does not fit into the support brackets on the radiator support. Culpepper says they cannot repair my old radiator its to far gone.
In order to get the radiator they are selling me to fit I have to notch the lip of the radiator support which to me looks like it will weaken the support. Is this the correct method of installing a thicker radiator? I would much prefer a stock radiator for that truck but even LMC does not have a radiator that fits the measurements of my original radiator. Any ideas? I can send pics later for better clarification. |
10-09-2013, 08:53 AM | #2 |
I am a Referee of life.
Re: Help Sourcing a Radiator
That's a common mod to add the thicker radiator.The mounts and cushions need to be changed and that requires a notch or slight bending of the support.There have been a ton of them done by members,so I doubt it affects the supports strength very much.The cooling capacity will be enhanced also and it's a good move if you plan on adding air anytime.I think I gave right at $200 for the rad and maybe $30 for supports and cushions.Look at it if you install one,I needed to put a shorter spacer between water pump and fan for clearance.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
10-09-2013, 11:04 AM | #3 |
If it were mine I would get the local autohouse replacement and a set of 4 core radiator supports & cushions, and do the mod. You'll get increased cooling capacity and have a good part that's easily replaceable in the future.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
10-09-2013, 02:16 PM | #4 |
Thanks for answering my post. Yea I guess I can bend the lip vs cutting it. All good points on going with the 4 core. Thanks !!!!
