Air bags for a daily driver?
I have a question and may be silly but is air bags good for a daily driver?
Re: Air bags for a daily driver?
Lots of 18 wheelers have air suspension systems with a million miles. I don't have one, but properly done I don't see why not on DD.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
I just bagged my truck and don't think I will have it any other way now. I'm living the low life from here on out
Scott 67 c10 sold 89 c1500 90 k2500 91 s10 #chevyonly ![]() |
Not to highjack your thread but I was kind of wondering the same thing, except I was wondering about what ride heights you can do with air bags. Can you go from stock height and down from there a few inches? I've never had anything to do with airbags so I'm completely clueless on it.
1970 GMC |
#5 | |
#6 | |
Never actually measured it, but it seems to be about 7" or so. I have 22s so it seems like there isn't much wheel well anyway.
I stopped adding up how much I spend on my builds, it only makes me doubt my sanity knowing I've spent more than 9 times it's original value new.
#7 | |
That looks pretty close to 'stock' ride height, which is something I want to keep, but also be able to drop it when I want to. I live in the mountains and have a dirt/rough/steep driveway so I don't want to be much lower than I am now.
1970 GMC |
#8 | |
Here is a lonk to our Pro1 air ride kit that uses quality parts from Porterbuilt, VIAIR AccuAir, AirLift.....uses all DOT fittings and air line. Let us know if we can hep you out any. http://www.azproperformance.com/Pro1...r-Bag-Kit.html |
#9 | |
I'm no expert on bags by any means but have a basic understanding. For your front bags you can run a bag plate (bolts to upper spring pocket) and a lower cup that sits in the lower spring pocket. Mixed with a drop spindle this will set you pretty low and as long as your backspace and tire size allows you shouldn't have to touch you inner fenders. Out back if you have trailing arm set up you pretty much bolt a bag in place of your coil. With a small in frame notch you can set your truck level with the front. You also will need shock relocates and adj. panhard bar. Air management can be 500-2500 depending what you wanna go with. This is where my little bit of knowledge runs out since I havent done anything with it yet. Travis at properformance or Nate at porterbuilt are very knowlegable on the subject and may be worth it to shoot them a pm. Hope this helps you a little
Good thread as I too am interested. Keep debating on static/air ride for my '67. One minutes its static then the next it's air. I'm building a driver/hot rod.
Ryan 1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840 1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628 1967/71 Blue SWB C10..SOLD 1977 SWB K10..my grandpa's.....never should have sold |
I just got a great deal on a truck with a brand new system in it so for less than half the price I have a bag system guess it was an easy decision. I'll start a build thread once I get rolling as I am doing it all myself
I semi-daily drive my truck, averaging about 250 miles a week on air ride. Rides WAY smoother than the factory 3/4 ton coils, and I'm adjustable for those steep driveways at Chipotle.
MSHax, I have 3/4 ton also. I pretty much have a system ready to install, minus two bags. My hang up is the front bags. My understanding is that they rub on the turn stops. Is this not true? What size bags do you run? Thanks for the info.
Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
#15 |
I'm using the ridetech coolride bags. I bought this kit here Link to bags
I have zero rubbing riding normal, or dropped all the way, for some reason I will get a slight rub if I'm locked all the way up, and am turning all the way to the left. But then again, I will never ride all the way up, and very rarely turn all the way. I did want to say something to anyone new to air ride, make sure you have a sway bar. If you don't have a sway bar, you will ride sideways, the way the sway bar will keep you level. I'm 195lbs so you better believe my driver side was lower than my passenger side. I also cringe every time I see someone twisting and tweaking their frame with individual corner control. I have my front tied together, and my rear tied together. I only have 2 switches; front, and rear. The install is kinda sad on these trucks, it takes twice as long to get the old crap out, than it does to get the new stuff in.
#16 |
Thanks for the info. Like I said, I've had the compressor, lines, etc for years. I only planned on doing the back initially because I heard there was rubbing issues on the front. I guess I'll need to just buy the bullet and install it all. I've got cups and plates too. I only really want to come down about 1-2 inches. I really just want a smoother ride. I was concerned that if I didn't want to lower it much that I would have to run higher pressure to keep the truck up near stock height, and that would hurt the ride. Is this true or no?
#17 |
I currently don't have my pressure gauges hooked up since my dash is currently torn apart for my next wild and exciting fiberglassing adventure. But I drop my truck all the way, then give a quick tap for the front and the rear and ride like that, as long as you don't have any leaks, you can ride at any level you want, and it's the same (as long as you're off the bump stops, and not locked up). I was driving down the freeway and a bunch of crap fell off this beat up ford thing. I quickly raised it all the way up to clear the road shrapnel. That was my first time locking it up on the freeway and it scared the bajesus out of me, as I ran over all the crap they dropped I felt like I had no control. Not safe all the way up, BUT...on the other end of the spectrum, if you've got a girl in the cab, who happens to have a nice top end, feel free to ride on the bump stops and enjoy the show.
#18 |
As long ss you take your time in the install and use quality parts daily driving a bagged (or juiced) truck is a snap.
#19 |
Good advice, don't cut cost on things like bags, have a bag blow out at 90mph would not be cool. My additional advice would be to test for leaks BEFORE you put it all in. The front on these trucks is not fun to pull back apart to fix a line leak. I've always used teflon tape, some people recommend the liquid, but after talking with the guys at ridetech at the last goodguys show, they said use blue thread lock, gotta try that next time
#20 |
Nice, you put the beer can in there for reference, its always my choice object as well.
1970 GMC |
#21 |
Air ride is the best ride for sure.
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
#22 |
I took our 68 suburban from Ontario Canada to Tennessee towing a car trailer think it was over 2100 miles. When I got home I put it in the shop and pulled insurance off it. Its not going back on the road till I remove the Air ride tech E2 set up, and install a system with ride height sensors. The alignment is very difficult to get right on pressure sensors alone.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
#23 |
I drive mine daily its the 5th car on air for me no other way to go in my opinion
#24 |
Glad this came back up. I installed Accuair a few years ago its a amazing system. The first pitcure the suburban has 30 66lb bags of quick concrete in the back. Perfect alignment all the time no matter what the load.
#25 |
