Help Heater Switsh Mod?
Ok heres what I got A 64 GMC with a standard hearter and switch (Off,On, High) heres what I want to do, make the switch a toggle and get rid of the standard switsh anyone done this, or steer me to wireing a toggle to work?
Re: Help Heater Switsh Mod?
A single pole, double throw switch should work...Or is that a double pole, double throw?
Jeff 96 C3500 Crew Cab Long bed (Waiting on Cool Name) 64 C-10 shortie stepside, "Ole Brownie" C-10 Club My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345 |
I'm interested too. I'm thinking of doing the same think on my 66' w/ Deluxe heater. I have no heat right now
So would I have to put some kind of resistor inbetween one of the poles to slow the fan down?
8 vehicles only 4 that run
![]() Join Date: Feb 2006
95 2500 350 w/ 3.73 ![]() 72 GMC 1500 SWB stepside 65 Chevy C10 SWB stepside 72 Chevy C10 LWB fleetside |
either will work if you have a double pole double throw then you would only use one side or if you used both sides (with jumpers from one side to the other)it would last longer
![]() Join Date: May 2007
make sure its rated for the current, a cheap toggle switch will catch fire before the fuse blows.
find the fuse rating on the blower at high speed and use that to find a switch. chances are the right rating toggle switch will cost a few bucks more than the cheapest.
Here is a switch that is OFF ON ON instead of ON OFF ON. Even calls it a heater switch. Its $11 plus s/h. http://www.elecdirect.com/product/17...31931135d.aspx
Thanks guys it looks easier then I thought
Way to go Clemson! I'll have to have my buddy get one for his heater, he lost the switch. I noticed that is a Cole Hersee switch, which are available at "good" auto parts stores.
