Old 10-14-2013, 02:08 AM   #1
PAWS 72
PAWS 72's Avatar
10'' rims
Cant remember if I have asked but
Is it a given that if I run some 10'' wheels on my truck that the frame is going to split where the steering box mounts against the frame? Not going to run them long.A few months at the longest.
I dont want to hurt or weld on it any.Or can I put some flat washers against the frame to keep it from splitting?
Thanks guys.
PAWS 72 is offline   Reply With Quote
Old 10-14-2013, 07:32 AM   #2
frog210
Re: 10'' rims
ive had mine on for a year or 2 and everything's fine. I didn't know that was a possibility?
San Antonio, TEXAS
-Frog
-I'm a valet and well I've driven BMWs, Mercedes, Porsche,Bentlys, fiats, Hondas, etc and well even do I like a few features, I love my shortbed, it dosent bore me out, just press on the gas and you'll remember why you love it.
frog210 is offline   Reply With Quote
Old 10-14-2013, 09:17 AM   #3
PAWS 72
PAWS 72's Avatar
Re: 10'' rims
My son's 87 split at the steering box. The guy at frame shop said that he has fixed alot because of the wide wheels and the frame is thin.
That was the reason I asked. I have seen where the 4X4 split at the box and saw where the people said they broke away from the frame. Thanks
Old 10-14-2013, 12:22 PM   #4
bbbc10
Diggin The SquareLife
Re: 10'' rims
its not cause of the wheels.....it happens a lot on these trucks
bbbc10 is offline   Reply With Quote
Old 10-14-2013, 09:10 PM   #5
PAWS 72
PAWS 72's Avatar
Re: 10'' rims
ok. that explains the thread. I had to have a reinforcement plate put on my son's 87. After reading some posts on here I thought because of the 10'' wheels and 275's on them.
I have thought about a plate on my 86 but dont really want to mess with the frame.
Old 10-14-2013, 09:37 PM   #6
f.monroe
f.monroe's Avatar
Re: 10'' rims
I think one tons came from the factory with braces that run from the crossmember to the frame rails. I would look through the salvage yards for a pair of them if you have any concerns.
Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 10-15-2013, 01:40 AM   #7
PAWS 72
PAWS 72's Avatar
Re: 10'' rims
Frank
Thanks.
Old 10-14-2013, 01:45 PM   #8
kalbert
Re: 10'' rims
There are reinforcement brackets of various styles available to strengthen and or repair the area where the steering gear bolts on. It's because of the added stress in the steering area in extreme conditions like hard cornering or off road. It can happen to stock trucks used heavily not just those with bigger tires or more grip.
kalbert is offline   Reply With Quote
Old 10-15-2013, 01:55 AM   #9
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: 10'' rims
Said braces.
Old 10-17-2013, 01:00 AM   #10
PAWS 72
PAWS 72's Avatar
Re: 10'' rims
Originally Posted by KQQL IT View Post
Said braces.
Thanks.I know what I will be lookin for. I may know where some are at.Was that 1/2 or 3/4 ton?
Old 10-17-2013, 02:07 AM   #11
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: 10'' rims
Never seen those braces in a one ton. They year specific?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 10-17-2013, 09:39 AM   #12
68Timber
I know the pieces fit
68Timber's Avatar
Re: 10'' rims
The frames were cracking behind the steering boxes back when these trucks were new, but back then it was only on 4x4 trucks with big lifts and tires. The steering box braces have been around as long as I can remember. 10" wide wheels are not necessarily the kiss of death. It helps to keep in mind that these trucks have extremely over-boosted power steering and just because you can go lock to lock sitting still with one finger doesn't mean you should show all your friends. Cranking on the steering wheel sitting still can be worse than wheel/tire width.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 10-18-2013, 02:07 AM   #13
PAWS 72
PAWS 72's Avatar
Re: 10'' rims
Thanks guys. Just want to run different wheels for a while
I have some 10's and thought about them.Just different
Here is the son's truck that's getting parted I think.
