10-14-2013, 04:27 PM | #1 |
What's causing this?
Something must be hooked up backwards with my truck's power door locks, but what exactly? When I'm on the driver's side and I hit unlock, it locks the passenger side. When I hit lock, it unlocks the passenger side. So they each do the opposite of each other. Not very practical. I end up having to lean over there every time and just push the doorlock down.
This will be the first time I've ever actually worked on door lock actuators, so I'd like to go in armed with at least some information. Is there just two wires per actuator? If so, perhaps I could simply reverse the wires at the actuator, and it would be fixed. If not, what's the easiest method of getting it to function correctly? |
10-14-2013, 06:03 PM | #2 |
Re: What's causing this?
Ya just reverse the polarity at that actuator, should fix it right up...
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded '03 burb. Family cruiser http://upstategmtrucks.com/ |
10-15-2013, 12:56 PM | #3 |
Yes - just two wires.
Typically what happens is the square switch gets installed upside down in the door trim panel causing "up" operation when pushing down and vise versa (for either power windows or locks). K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
