Old 07-10-2003, 04:34 PM   #1
Silverado6.6
shackle lift-FRONT
Has anyone ever had anything to do w/ one of these set ups??? I've seen them advertised on coloradoK5 I believe....I'd like to hear some kind of feedback on them, I'm wondering if they'll work on my one ton...........anyone??
94 S10
82 K30
81 C20
80 K20
76 C10
69 C20
68 C10 4 sale
51 3600
Silverado6.6 is offline   Reply With Quote
Old 07-10-2003, 08:31 PM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I've installed ORDs heavy duty front shackles. They were 1/2" longer than stock so only netted 1/4" lift. They required up-grading to 1/2" bolts from the 7/16" stockers. They slightly turn the diff back which increases caster slightly. With my 2" lift and the shackles I have no binding at the front u-joint. Anything longer than this(1/2") and you'd probably have to install shims to rotate the diff back up. I've heard of people installing 2" longer shackles with 8-12" lift springs with shims to clear some big tires.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
