Questions for those of you that have installed one piece side widows
I’m thinking of installing one piece side windows in my 65 daily driver. I’ve searched and read most if not all of the post on this modification and I think the issues/concerns can be summed up as follows;
1. It requires a lot of cutting to the door, and the vent windows will be destroyed. 2. The door check may be in the way 3. Removing pieces of the door’s internal structure may leave the door “flimsy” I’m not concerned with issue 1 I’m pretty good at metal fabrication. So what is you experience with the modification and did you have any problems with issues 2 and 3. Since this is my daily drive I have one more questions, any issues with wind noise or leaking while driving in the rain? Thanks for your Help |
Re: Questions for those of you that have installed one piece side widows
Check out this thread...he may be able to help. He just did one piece glass on his 63 and it looked like he didn't have to trim the door at all. Might be worth a shot to talk to him and the vender he used.
http://67-72chevytrucks.com/vboard/s....php?p=6313790
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
#3 | |
![]() Join Date: Feb 2011
I did the conversion on the 63. The kit required not door modifications only had to drill three new mounting holes. It used the original rear track and a new from track was provided with the kit.
