WTB 3.73 rear end for 71-72
Looking for a nice 3.73 coil spring rear end for a 71-72 half ton. Doesn't need to be a posi, but does need to be fairly clean, don't want to have to replace the brackets on it. Also only looking for local, with in the KC area.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html Last edited by ls1nova71; 11-26-2013 at 08:15 AM. |
Re: WTB 3.73 rear end for 71-72
Anybody reasonably close have anything? I would probably take any gear at this point. Also brakes are not important.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
Ttt
There isn't a rear end in this city???
Hey man are you looking for the whole 3rd member? drum to drum?
I think I have a differential for a 3:73 but just the unit and spiders, no ring or pinion etc. Did you check with Joe R. up in Independence? He has a lot of things. Tim |
I need a whole rear end, drum to drum, but since I'm putting discs on it I don't really need the drums. Lol! I've known joe forever, he doesn't have anything. We were talking the other day how it used to be you couldn't give away a 3:73 rear end since everybody wanted 3:07s, now they aren't anywhere to be found. BTW, the blazer I need it for used to be Joe's, I'm making it a 2wd.
ls1, I've got a rear end you might be interested in.. It's my spare but, I might part with it for the right price. 69-70 coil sprung rear with a posi carrier in it. Has brand new Richmond 3:73 gears in it that were installed 3,000 miles ago. But, still has the 6 lug axle shafts. Everything but the brakes were gone through 3,000 miles ago when the ring and pinion were put in..
"Repetition penetrates even the dullest of minds" |
#8 | |
So I took my 3:07 out of my short bed frame and had it rebuilt with a 3:73 posi, so I'm good to go on my current project. Still need another one to put back under the SB frame. Just needs to be 71-2 and 3:73 gear, non posi is fine.
![]() Join Date: Aug 2004
They sure are getting hard to find in my neck of the woods also. Id like to have a spare just in case...
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Does the guy in Lenexa have one? Also, look on C-list in Ark City, KS. A guy is selling a TON of stuff. Does Teeitup have one?
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
