Old 10-17-2013, 04:13 PM   #1
64shortbed
64shortbed's Avatar
Heater replacement?
I'm in the middle of getting my new to me cab ready to put on my 64 gmc. i have the deluxe heater in the truck now. My question is has any one ever put a heater from a differant car/truck in their truck to remove the "bread box" under the hood and clean up the firewall?
64shortbed is offline   Reply With Quote
Old 10-17-2013, 04:38 PM   #2
da_bears_da1
Re: Heater replacement?
There actually was a heater that did not use have the bread box called a recirculating heater. The only thing you see on the firewall is where the core tubes come through for supply and return. If you are looking to get rid of the bread box, that would be a model year correct solution.
Jeff
Simplify Life!
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=566533
da_bears_da1 is offline   Reply With Quote
Old 10-18-2013, 03:26 PM   #3
64shortbed
64shortbed's Avatar
Thanks but that really wasn't my question. I was wondering if any body ever put heater/ac from another year car/truck in their 60-66. And if it fit under/behind the dash.
Old 10-18-2013, 04:04 PM   #4
LVPhotos
LVPhotos's Avatar
My non deluxe heater did not have external box. Vintage Air has just heater if that is what you are looking for. Small enough to fit in a Deuce. Of coarse they have direct fit AC/heat.
This is a shot of the fire wall. I will have to find out where I left the other pictures.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 10-18-2013, 04:06 PM   #5
LVPhotos
LVPhotos's Avatar
here is the link to other thread.
http://67-72chevytrucks.com/vboard/a...1&d=1378423899
http://67-72chevytrucks.com/vboard/s...d.php?t=595550
http://www.speedwaymotors.com/Flex-A...Heater,304.htm
http://static.speedwaymotors.com/RS/...t/359640_R.jpg
