Old 10-18-2013, 08:48 AM   #1
bigmac73
bigmac73's Avatar
Clunk, Klink when is putting in gear
sometimes i get a clink when I put my truck in gear either FWD or Rev, I thought it was the U joints, but I got under neath they all feel tight, I tried to shake and move them up and down by hand, no kind of movement, at all.
any thoughts, maybe my pinion gear is wore, I had the gear fluid changed a couple of years ago, and the garage said everything looked good inside no issues or shrapnel was found
U joints and carrier bearing are about 3 years old
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
