LS (VORTEC4.8) weights
Google has gotten me close but I'm trying to find apples to apples weights.
Comparing different V8's for a possible engine swap. I get the feeling all the old school charts show long block weight and LS sites are mostly quoting dressed weight. Is there a concession on iron block LS (vortec) weight vs. aluminum LS weight ? I already have size specs.
"I feel the need for speed!"... as soon as I am done with my nap. |
meowMEOWmeowMEOW
Re: LS (VORTEC4.8) weights
LS1/2...........106
LS7..............107 RHS..............110 Dart Billet......128 6.0L Iron.......216 LSX..............230 Aluminum truck block is within about 10lbs of the ls1
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
Hey BR3W CITY thanks! I think your post is bare blocks? I may have been a bit misleading (after re-reading my post)
I'm looking for long block weight w/o clutch or A/C or serpentine set up.
Is the LSX referring to 4.8/5.3/6.0?
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
meowMEOWmeowMEOW
No, thats what the "6.0 Iron" is.
LSX in all caps (vs LSx or Lsx) is supposed to refer to the actual LSX block, the highest cube possible block, which can end up in a number of different displacements. Its an aftermarket only block.
meowMEOWmeowMEOW
I VERY highly doubt anyone has decided to weigh every semi-long block. There are too many variations on what people call "long" in terms of what is/isn't attached.
But look at it this way. The front accessories and dressings on almost all of the engines will weigh just about the same. Every pair of dressed heads weighs pretty close to the same (stock heads, all of them are aluminum). The only real differences in the weights at all, will be within the block. So if you have all that, you really do have all the information you need to make a choice, you just gotta read between the lines a bit. What exactly is your weight concern? Compared to almost any old iron motor, any configuration of these newer motors will weigh in the same if not less, make more power, be more efficient, and in some cases even take up less space.
#7 | |
However, have to look at all options and LS is one of those. Size wise the SBF wins by a small amount. Both have been done. It boils down to what works best for me. Best = ease of swapping, total cost, drivability. I don't need every variation, I do need something to go by. Still looking.
meowMEOWmeowMEOW
Unless u can find an aluminum sbf then the lm7 would be lighter.
#9 | |
"Weight of 5.3 LM7 (iron block) 518 lbs fully dressed and wet" I'd say a SBF @ 460 lbs. then add aluminum heads and it will be lighter than a LM7 probably not an LS1, once dressed. In fact a dressed* LS1 is reported like this... "Total dressed engine mass (wt.) dry 457.6 lb. automatic 497.2 lb. manual" Dressed means different things to different people. The LS1 was suppose to be taken from a GM site (no longer found) So I'd take these figure with a grain of salt. something to use for "ballparking it"
I don't see the 6.2 on there. Any ideas on weight?
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
meowMEOWmeowMEOW
It doesn't help that I stated the wrong engine
![]() The L33 is the code I meant to refer to. The aluminum blocked truck engine, which weights approx 85-100lbs lighter than the iron block (*Depending who's number you trust). This would be in the neighborhood of 60lbs lighter than an aluminum headed sbf, and probably 125lbs or more lighter than an all iron small block-anything. ballparking to say the least, but any way you do the math it comes out a bit lighter.
