10-19-2013, 06:10 PM | #1 |
How many blots hold the engine cradle to the frame?
Holy smokes... how many blots hold the engine cradle to the frame of a 69 truck 2wd? I counted 4 per upper control arm and 3 bolts on each side lower frame. Am I missing something? I thought for sure this would fall right out...
10-19-2013, 06:45 PM | #2 |
Re: How many blots hold the engine cradle to the frame?
How about two more on each of the engine mounts to cross member
10-20-2013, 12:52 AM | #3 |
Ha Ha those came off first. It must be rust holding this together. I have two frames and I noticed something cool. One has the engine (hold down/ loop on the LH side of the frame)? riveted to the frame and the other is bolted on the frame.
10-20-2013, 01:29 AM | #4 |
BlahBlahBlah
Im checking out this thread just so I can find out what the heck a blot is
10-21-2013, 02:00 PM | #5 |
Florida Edition
That should be all of them if you are talking about the crossmember. Might want to whack it with a sledge to break it loose. Could be bound up between the frame rails a little.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
10-21-2013, 03:50 PM | #6 | |
Florida Edition
The pic isn't the best but you'll get the idea.
10-21-2013, 06:32 PM | #7 |
Thanks Reno, that's what I thought. This frame has been sitting exposed to the weather so it looks like time for the B.F.H.
