Old 10-23-2013, 06:12 PM   #1
JNJchev77
Registered Cruiser
JNJchev77's Avatar
Cab interior carpeting...
I am trying to get some ideas on how to go about the interior cab floor. Because of the Dropmember and LS Swap, I've had to modify the floor/trans tunnel for clearance. I've sprayed the floor with POR15, topcoated with Raptor Bed Liner, then laid down a layer of sound deaden-er. I can't use the factory molded carpet because of this...
My question is, what can I use for carpeting that will contour around these areas, and the rest of the cab, and still give a simple factory look?
77' Chevy SB
Dropmembered Front and Rear
5.3/4l60e combo
JNJchev77 is offline   Reply With Quote
Old 10-23-2013, 06:28 PM   #2
nekkidhillbilly
Re: Cab interior carpeting...
4wd truck carpet? the trans tunnel is higher. only other thing i can think is use roll carpet and hit it with a heat gun where you need it to bend.
nekkidhillbilly is offline   Reply With Quote
Old 10-24-2013, 04:40 PM   #3
JNJchev77
Registered Cruiser
JNJchev77's Avatar
Thanks Nekkid! I was leaning that way, but checking to see if their are other options.
Sounds like that may be the easiest solution.
77' Chevy SB
5.3/4l60e combo
