10-24-2013, 03:08 AM | #1 |
Using coolant
Have a feeling I'm using coolant through edelbrock 2116 intake, only 6,000 miles on complete overhauled 283. Any other places coolant would be used up?
"gotta love something that works without a computer" |
10-24-2013, 03:33 AM | #2 |
Re: Using coolant
Water pump. Look behind the pully where the shaft comes out. That is a typical location also look for white corrosion on your radiator this usually suggests a leak as well.
Just trying to figure this out... 1970 SWB Step-Side http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=584499 1970 SWB One Owner Step Side 6.0 LY6/6L90 http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide http://67-72chevytrucks.com/vboard/s...86#post7531186 |
10-24-2013, 08:34 AM | #3 |
Re: Using coolant
most common is newbies dont know how to properly fill the radiator /// to the brim and it goes out the overflow hose when hot and guys just keep toping off the level and it keeps running out the overflo
10-24-2013, 08:57 AM | #4 |
Re: Using coolant
CDOWNS is absolutely correct--leave the level at approx. 2 inches[iirc?] below the rad. "ring" when it is COLD....or, add an overflow bucket with overflow tube properly connected. The 2nd alternative is preferred by many: it acts as a temporary storage for expanded fluid when hot and allows rad. to reclaim it when it cools down and "vacuums" that excess back into system.
Sam |
10-24-2013, 01:50 PM | #5 |
Re: Using coolant
Bad head gasket or cracked head will cause loss of coolant into the combustion chamber. You will see white smoke (steam) out the exhaust if its leakng bad enough.
10-28-2013, 03:41 PM | #6 |
Re: Using coolant
I think it's the intake gasket, there notorious for leaking, aluminum to cast iron head..........I'ts burning coolant, I can smell it, have overflow reservoir and its not filling up, water pump is new, new heads everything is new.
10-24-2013, 02:48 PM | #7 | |
Re: Using coolant
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
10-28-2013, 03:36 PM | #8 | |
Re: Using coolant
10-24-2013, 03:09 PM | #9 |
Re: Using coolant
Another thing that will cause a loss of coolant is improperly sealed head bolts.
10-24-2013, 05:05 PM | #10 |
Re: Using coolant
How does the oil look? If it is a milky grayish color, then you have serious problems. Or one possibilty is the intake gasket(s) got moved while the intake was placed on the motor.
2005 GMC K2500HD D/A 1993 GMC K1500 2011 Subaru Legacy. 2013 Subaru Outback 1970 C-10 2WD, SWB stepside, 292, TH350, PS, more rust than anything. God is my pilot. |
10-28-2013, 03:46 PM | #11 |
Re: Using coolant
No, oil is fine, pretty much sure it's an intake issue. Just need to do a tear down.
10-28-2013, 04:57 PM | #12 |
Re: Using coolant
Check your spark plugs. The cylinder that is burning the coolant will have a very clean plug. Then at least you will know where the leak is. You can pull the heads to do the same thing. But with no oil problems i say intake gasket.
10-28-2013, 06:51 PM | #13 |
Re: Using coolant
Did you use the fiber intake gaskets or the plastic Fel-Pro. I like to use the fiber Mr. Gaskets. I use Permatex form-a-gasket in the little tube around the water ports. And hi-tack red brush on around the intake ports. Edelbrock has a intake gasket for they're alum. intakes but I have never used one.
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member). |
10-29-2013, 10:48 AM | #14 |
Re: Using coolant
The heater core is a good point. Let us know what you find.
