Straight 8 fitment?
I just got a 1950 chevy that I want to eventually put a unique power plant in besides the tried and true 350 small block. I have a 292 6 in my 53, so I'm wondering if a Buick straight 8 would fit in the engine bay. I would go measure for myself but I'm away from both truck for a while. I've tossed around the idea of the straight 8, nailhead, 331 caddy and a 348 chevy. If anyone has more unique suggestions feel free to chime in. Thanks
Re: Straight 8 fitment?
I think your idea of the 348 is solid. But tell everybody it's a 409.
56 Chevy PU http://67-72chevytrucks.com/vboard/s...d.php?t=531955 Question: Know how to sell your truck for $50,000? Answer: Spend $100,000 building it. |
a nailhead would be my choice
I'd LOVE to get my hands on a 409 but the 348 will have to do like you said. I'll have to do some research on the performance parts for those. I'm leaning towards a nailhead too, but I've heard they don't like manual transmissions behind them for whatever reason
![]() Join Date: Aug 2012
This doesn't seem to fit the theme of the older-school motors you listed, but in case any part of your brain is tempted to go for a modern powerplant, I was strongly considering a Vortec 4200 straight 6 for my build. They are absolutely incredible engines. I ended up going with an LS V8 instead, but I often find myself thinking about the modern straight 6 option instead.
With modifications it will fit. A short shaft water pump would be needed. Then take a note from Pontiac and cut the firewall back a hair. (Yes they did that)
I did have the idea of going with an Ls series series motor but I don't know if I would know how to hook up all the electronics. I wouldn't mind a modern 6.0 or 6.2. Just for the cool factor and not to mention some reliability. Which ls did you go with torch? I'm mainly getting ideas together for when I start this project after college. And thanks Zach, I'll check out the measurements when I'm back home.
Oh and I'm kinda liking that vortec 4200 option too. From 06 and up they put out 291hp, not too bad. I might have to start checking out some wrecking yards around here.
![]() Join Date: Aug 2010
Speaking of Pontiac how about the OHC 6 IF you could find one.
Glen & Jane's Rides ‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008 7 other cars & trucks , 5 trailers '56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020 ’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020 My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275 |
That's a cool engine, seems like it was ahead of it's time. It would probably be pretty hard to find with only a four year run but I'll keep it in mind. Thanks
If you like heavy iron, how about a 60 deg V6 truck engine? Smallest displaced 305 cubes, largest was 476 cubes. There's also a 635 CI 8 cylinder and a 702 CI "twin six" V12 engine.
http://gmauthority.com/blog/2013/05/...history-alley/ http://6066gmcclub.com/gmcguy/gmcv6a.html If you'd like to lighten the load, Oldsmobile and Buick used an aluminum 215 CI V8 in the early '60s. The engine had issues in original form, but after GM sold it to Rover (from England) many of the bugs got worked out and since the original design, versions as large as 4.6 liters have been used to power Range Rovers as recently as 2002. Many parts are available for this engine family including fuel injected intakes, turbo manifolds, high compression pistons, etc. http://www.aluminumv8.com/tech/tech.htm http://en.wikipedia.org/wiki/Rover_V8_engine |
Fellow here in town has a Cummins 4BT in his. Solid truck, sounds great, no smoke & runs good. Neighbor has a Mopar 440 in his that replaced a Pontiac 400. Was a ***** of a job tho. But his truck sits on a modified 77 Pontiac leMans frame. Turned out nice too. I know where you can buy a complete 270 Hemi early 50's. I've seen one with a 3-53 Detroit even, but that was a long time ago. A 4.3 V6 Chevey truck engine would be a good choice, IMO.
I am intrested in the 4200- late six as well . Anyone done that swap yet????
a friend of mine was going to sbc his 52 buick w/ straight 8 322.
he was going to donate the motor to my panel project. it's a really long motor, but i think it would be a head turner at shows.
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
#15 |
polishing a turd
I may be pulling my straight eight at some point from my 53 special, but probably hanging on to it for a model t roadster project
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512 53 buick special - straight 8 sled - blow through turbo 47 gmc - flatbed hot rod build 99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van' |
#16 |
only problem with the straight 8 is that there are limited horsepower parts for it.
That's the beauty of a small block chevy, lotsa parts, and they are reasonable, because a chevy v8 has been put into everything made on wheels .
http://http://67-72chevytrucks.com/v...d.php?t=489721 |
#17 |
Awesome suggestions and ideas here guys that's exactly what I was looking for. I think I'd like to keep it to where the engine looks like it belongs in there. I have plenty of time to think about it too, just trying to get some cool ideas rolling. Thanks for the links too, I'll start looking into engines that have some aftermarket parts available for them.
#18 |
speed parts? that would shoot the straight eight idea all to heck
![]() though you could do a turbo and make a nice split header
#19 | |
Don't be afraid to mix old and new technology though. It's neat to put in an old powerplant but retrofitting it with modern electronic spark control and EFI can make a new engine out of an old boat anchor. A straight eight with a multiple TBI intake and a header would be very cool imo and should run circles around the original configuration. http://www.youtube.com/watch?v=tDoA4HJNf-I |
#20 |
That video is awesome! I don't know if I have the skills to build up something quite like that but it would definitely be a head turner. Do people fab their own manifolds and stuff for these old motors? Not just the straight 8 but just in general for engines that don't have much of an after market selection.
#21 | |
![]() Join Date: Jun 2013
I think an older Buick V8 may be narrower or it may just appear that way due to upright rocker covers. The 292 is a great engine.
Gale Gorman '54 3100 '67 C20 stepside |
#22 |
Actually in 1917 chevy produced an engine much like the the the Buick V8 with upright rockers. I'm not sure that something that old and rare (if you can even find one) is something I would want to use. Chevy quit making that type of engine because it was to expensive at the time to be profitable.
