10-27-2013, 11:06 PM | #1 |
Bolt in notch?
Does anyone have a pic or know how low I can go with a bolt in notch. I intend to use bag on trailing arm and a 2 inch block and run a 255-35r20 tire
10-28-2013, 08:40 AM | #2 |
Re: Bolt in notch?
Bolt in 'STEP' notch or 'C' notch?
10-28-2013, 11:00 PM | #3 |
Re: Bolt in notch?
I just finished my c notch today, I have 2 inch lowering shackles and flip kit, and also am doing a lowering block with bags soon, but without bags and block my axle is 4 inches from top of c notch
10-28-2013, 11:45 PM | #4 |
Re: Bolt in notch?
Here you go. I have the Porterbuilt 2 PC notch, SS7 airbags, and 2 inch drop blocks. I don't have the bump stop under the notch. I'm pretty sure I will use them as a added precaution to keep the rearend pumpkin from slamming the bed and denting it
Scott Last edited by sduckworth13; 10-28-2013 at 11:51 PM. |
10-28-2013, 11:54 PM | #5 |
Re: Bolt in notch?
Here is a link for the Porterbuilt 2 piece C-notch. It is by far the most installer friendly notch on the market.
http://www.porterbuiltfabrication.com/?p=385
Scott |
