Old 10-29-2013, 11:58 AM   #1
manimal
manimal's Avatar
What kind of wood?
I have a flatbed on my '75 GMC 35...it looks like the same wood used in standard pick-up beds. I am considering making my own,but need to know what the right router bit would be to cut for the steel strips?
Any help "WOOD" be greatly appreciated!..lol
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 10-29-2013, 12:33 PM   #2
1981Stepside
1981Stepside's Avatar
Re: What kind of wood?
Run the boards through a table saw with a fence and adjust the height of the blade. I had a real hard time finding a router bit to make the proper shape/depth cuts.
Proud UA member since 2009
My LT1 Silverado build-up: http://67-72chevytrucks.com/vboard/s...d.php?t=549660
Check out my new YouTube channel! - https://youtube.com/channel/UCXk5mZOQI1sEnu5bIkhe7fA
1981Stepside is offline   Reply With Quote
Old 10-29-2013, 02:02 PM   #3
walkerb
walkerb's Avatar
Southern yellow pine is what came stock. Like 1981stepside said, table saw works well, just make the inside cut( where the strips will set) a 1/8" deeper.
1973 k20 Suburban 350
1974 Custom stepside c-10 250
1975 Chevy stepside 454
1986 K30 Crewcab SRW 350
R.I.P- glimmertwin01- board member and good friend, you will be missed
walkerb is offline   Reply With Quote
Old 10-29-2013, 03:09 PM   #4
manimal
manimal's Avatar
Just a std blade or a dado or what?
-Lance
Old 10-29-2013, 03:22 PM   #5
1981Stepside
Standard combo blade is what I used
Old 10-29-2013, 03:23 PM   #6
manimal
manimal's Avatar
Thank you!
-Lance
Old 10-30-2013, 09:05 AM   #7
manimal
manimal's Avatar
What would you guys recommend for wood? I looked at our local BIG lumber supplier(Peterman Lumber) and did not see Southern Yellow pine. Guess I will have to call them. This is not going to be a show truck. But I do want it to look nice and last. Thanks
-Lance
Old 10-30-2013, 09:23 AM   #8
walkerb
walkerb's Avatar
White oak is a really good choice, in my opinion. Very long lasting if exposed to the elements and looks great finished.
But you being in CA, redwood?
Old 10-30-2013, 09:36 AM   #9
Ironhorse
Ironhorse's Avatar
Knew a guy at work who was looking into using the new composite decking material for his truck bed. Think it was called "Trex" or something like that. Would still have a somewhat wood look to it but think it would quite a bit longer? Comes in 2x4 and 2x6 widths is what he told me and cuts and mills like wood. One drawback is it can not be stained, not sure of the colors offered tho. I plan on using it to replace the wood floor in my 5x10 utility trailer come spring. Just a thought for what it's worth.
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
Old 10-30-2013, 10:19 AM   #10
oldmann1967
I would highly suggest White Oak that has been quartersawn. They quartering makes it much more stable. It does not cup at all. Also, you can see the tiger stripe in it called medullary rays.
oldmann1967 is offline   Reply With Quote
Old 10-30-2013, 04:36 PM   #11
longhorn70gmc
longhorn70gmc's Avatar
I would recommend Oak. I used Pine in my Longhorn and it is starting to crack and seperate all ready. Harder the wood, the better. Good thing is your flat bed is straight pieces. I just picked up a 73 Chevy and am just using Plywood for now on the flatbed area. No smog at least. Would like to see How it comes out. OH YEA, good to talk to ya again!!!!
Billy
1970 GMC Sierra Grande 402/TH400
(Longhorn)14 years and counting rebuild!
1975 (Build) Chevrolet SWB 4X4 350 SB Lifted 6 inches
1970 Ford F250 Ranger 390 BB
2010 Ford Super Duty F250 XLT W/4 inch lift kit and Pro Comp Tires
Hub Cap Freak!
I need another truck like I need another hole in the head!
I'M IN THE MARKET...AS IT WERE!
longhorn70gmc is offline   Reply With Quote
Old 10-30-2013, 06:21 PM   #12
aotte1
Agree with previous suggestions on white oak, quarter sawn. I would stay away from red oak does not weather well. Two other woods I am considering are white pine from new England and walnut, they both weather well. Walnut is extremely tough and weathers very well. On the more exotic side you have western white cedar or teak ( a little expensive!). The western white cedar would also be a good wood to use, however, would take some effort to find. It is very weather durable.
Lastly I like a tung oil finish, durable and easy to touch-up.
Lots of choice, have fun
Les
aotte1 is offline   Reply With Quote
Old 10-30-2013, 08:40 PM   #13
Greenlee
Greenlee's Avatar
Check out the testing of various finishes and woods on mar-k's site. Been a while since I read it, but seems like the yellow pine lasted the longest. That is why I picked yellow pine for mine. It was also the cheapest and was used from the factory.
http://www.mar-k.com/installation_hints.aspx
Greenlee is offline   Reply With Quote
Old 10-30-2013, 10:05 PM   #14
manimal
manimal's Avatar
Thank You everyone!
-Lance
Old 10-31-2013, 01:24 AM   #15
lilpoindexter
lilpoindexter's Avatar
I would like to see a trex bed...i think it would be a good idea.
lilpoindexter is offline   Reply With Quote
Old 10-31-2013, 07:22 AM   #16
walkerb
walkerb's Avatar
I do understand the reasons why a person would use the trex (composite).
The problems or issues I see is
1. most composite thicknesses are 5/4 vs. stock 3/4 thick
2. mold. Most decks that I have done or repaired have a mold issue( but it good better in recent years)
3. structural. Real wood is able to take more abuse making the bed
4. Cant finish (poly or stain) like real wood
I'm not knocking the use of composite just that in my opinion wood make better sense.
Old 10-31-2013, 07:02 AM   #17
BigBlocksRule
^ agreed. I have a friend with a deck made out of the stuff, 4 years old looks brand new and it's on the south side of his house, full sun most of the day.
BigBlocksRule is offline   Reply With Quote
Old 10-31-2013, 10:36 AM   #18
Rich84
Rich84's Avatar
I think that you would have to add more cross sills as well..When that stuff gets hot it will sag.
Rich84 is offline   Reply With Quote
Old 10-31-2013, 10:38 AM   #19
Ziegelsteinfaust
What about appeton.
It is the type of wood used in trailer beds, and is really hard. Plus it has a lot of acids in it like red wood.
Ziegelsteinfaust is offline   Reply With Quote
Old 10-31-2013, 06:02 PM   #20
mrolds88
I think its spelled apetong. That's the stuff. Its what they use on tractor trailer type trailers. It has some weight to it and it wears like cast iron.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
