10-31-2013, 01:06 PM | #1 |
gas tank straps
I see two different after market straps for sale, one with holes on both ends (for the bolts) and the other with the front bolt pad and the rear is just folded over. do you drill the strap for the rear bolt? of course one is cheaper than the other. might just make my own.
1961 chevy K10 my build is------------61K10 build |
10-31-2013, 01:24 PM | #2 | |
Re: gas tank straps
using the std straps with holes, http://kieth.smugmug.com/Trucks/66-G...0605&k=WzzVJXB the rear of the tank straps : http://kieth.smugmug.com/Trucks/66-G...0612&k=GHLg7T2 Kieth |
10-31-2013, 01:41 PM | #3 |
Re: gas tank straps
thanks Kieth for the info. I guess i should of said straps for the stock in the cab tank. might go to the rear tank later and will use your info.
10-31-2013, 03:44 PM | #4 |
Re: gas tank straps
61K10...I have an oem pare sitting in a box here if you need a set. Boxed them for someone else and they decided they didn't need them. Just cover the flight.....
Came out of my 61 c-10 parts truck
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
10-31-2013, 03:57 PM | #5 |
But Found Her 25yrs Later!
Re: gas tank straps
I think the 60-62 straps are a little different than the 63-66
10-31-2013, 04:03 PM | #6 |
Re: gas tank straps
If you look at the back of the cab, about halfway up the back wall, there are brackets that the folded part of the strap slips in. The cab is a 66
10-31-2013, 05:30 PM | #7 |
Re: gas tank straps
good pictures of both gas tank straps here (best use of windows paint that I have ever seen)http://67-72chevytrucks.com/vboard/s...highlight=tank
11-01-2013, 03:08 PM | #8 |
Re: gas tank straps
so they must have changed in 63 or 64? here is a pic of mine which bolt down by the floor in back, not like the tabs on the back wall.
11-01-2013, 03:13 PM | #9 |
Re: gas tank straps
That's the set I have boxed up if you need them. They came out of the 61 in my front yard
11-01-2013, 04:07 PM | #10 |
Re: gas tank straps
thanks 63c-10 for the offer. i can probably fix the one i have that is broke. will pm you if i need them. so what kind are in your 63?
11-01-2013, 05:34 PM | #11 |
Re: gas tank straps
61K10
My 63 are bolt down like yours, maybe changed in 64 |
11-01-2013, 06:13 PM | #12 |
Re: gas tank straps
The same as the 61. No problem....they are just taking up space here. If you need them, cover shipping and they are yours.
