10-31-2013, 08:03 PM | #1 |
Can this be installed wrong?
I'm talking about the wiring harness plug that goes in the back of the instrument cluster. It appears that it will fit either way. I have the cluster with gauges and converted my harness (formally a idiot light harness) to work for the new cluster. Thanks, any help will be appreciated.
10-31-2013, 08:21 PM | #2 | |
Re: Can this be installed wrong?
Are there any hints in the assembly manual?
1970 C-10 LWB "Blu" Instagram (current build pictures) 70_nc_c10 |
10-31-2013, 08:43 PM | #3 |
There should be two tabs that will not let you install it incorrectly.
Study it and you should see the tabs on the connector and the mating slots in the back of the cluster tin.
1972 Chevrolet Cheyenne LB 1/2 ton finished restoration/rebuild 1995 350 throttle body FI, 4L6E (running on modified GM wiring harness) 3.08 posi rearend, factory A/C on 134A, p/s, p/b, late 70's power windows and locks and cruise, speakers in the dash + 6x9's behind the seat, factory tilt, 40 gallon fuel tank in the bed with integrated tool box, air assist bags on the rearend, sway bar up front and much more. 1972 chevrolet SNB finished 2002, 350 TB FI, TH400, factory A/C, p/b, p/s, (FOR SALE) 1969 Chevrolet 1 ton in work, home made PTO dump bed extended frame, 350 CI , 1972 Chevrolet 3/4 ton suburban future project 1972 Chevrolet 3/4 ton p/u maybe a project one day 1966 Toyota Landcruiser my playtoy |
11-01-2013, 12:32 PM | #4 |
Thanks John, what day do you plan to do it? I am very anxious to get this thing fired up!
Tlcrz1972, I looked pretty close and didn't see any tabs except the two locking tabs on either side. They were the same on both sides. I will look again this evening. |
11-01-2013, 01:00 PM | #5 |
The end tabs should be different widths. It should only go in the right way. Unless, of course you put the wires in the wrong cavities when you rewired it for gauges.
11-01-2013, 01:11 PM | #6 |
Thanks Firstowner69! It snapped right in on the first try so I guess I got it right.
