425hp409
![]() Join Date: Oct 2008
Disc Brake Conversion
I have a customer's 68 truck that his Dad bought new and I am in the process of making it mechanically sound and safer. It is a real nice Custom SWB truck with Factory AC, PS and an original 307/Powerglide. . The owner is real particular as to not make any real changes from when his Dad had the truck. I finally convinced him to allow me to do a Disc Brake upgrade, but I think I may have a problem doing it as the truck has the original wheels that I don't think will work with the Discs. Does anyone know if Discs will work with the 68 wheels, or will I have to change them out. I need to keep the truck 6 lug, so if I have to change them, will 71-72 blazer wheels work?
Thanks, Charles
Charles 68 SWB, Dad bought new, now 396 & factory ac 64 Impala SS, 409 425HP, 4 speed AC 64 Bel Air Wagon, 400 Small Block 57 Bel Air all original 283 w/Factory Air 77 GMC Sprint, 454/425HP 67 Olds 442, all original 90 ZR1 Corvette |
![]() Join Date: Mar 2012
Re: Disc Brake Conversion
i had a 69 in high school and went to a 8 in front / 10in rear wide wheel , i think they came off a toyota or new chevy at the time, i am sure that gives you more backspacing
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks ![]() |
There are companies that sell 6 lug disc brakes. However, you will need to change the wheels from pre-72 six lug wheels to 72-87 six lug wheels. The earlier wheels hit the caliper and wont allow the wheel to turn
You can tell what you have as the pre-72 have three nubs for the hub caps and the newer ones have four.
///Relaxed Atmosphere |
#4 | |
425hp409
Thanks, I will have to have the nubs for the hub caps to go back on. I didn't think the original wheels would work, but if I can get the later wheels and paint them, the truck would still look original and keep the owner happy.
got mine off of ebay. fit perfectly. was for 6 lug! was around $900 shipped for the front kit.
![]() Join Date: Dec 2012
Charles,
You could do wheel spacers in front too but that would push the front out. I think you only need 1 inch. If you do the wheels, make sure to get 5 of them so he doesn't have to jockey things around if he needs to use the spare.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
![]() Join Date: Dec 2007
Do you really need discs? If it's just going to be a grocery getter, leave it on drums? It's such a nice unmolested specimen.......
425hp409
The owner will be driving it some to his business in Dallas Traffic
