11-02-2013, 05:43 PM | #1 |
3" drop all around and not sitting even
I finished the 3" drop on the hind end of the truck and its level but not sitting even. Before or after.... I was hoping it was a bad coil making the truck sit crooked but with new springs all around, its still not even.
Before the drop (measured from top of wheelwell) Right Front - 32.75" Left Front - 32.25" Right Rear - 33.25" Left Rear - 33.00" After the drop (3" front, 3" rear, springs....) Right Front - 30.5" (-2.25") Left Front - 29" (-3.25") Right Rear - 31.75" (-1.5" Left Rear - 30.75" (-2.25") Not sure why its not sitting level but its starting to piss me off. Any ideas on what I can check??
1970 C-10 LWB "Blu" Instagram (current build pictures) 70_nc_c10 |
11-02-2013, 05:55 PM | #2 |
Moderator
Re: 3" drop all around and not sitting even
Frame is probably tweaked. Very common issue with these 40 year old trucks.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
11-02-2013, 06:05 PM | #3 |
I'm probably oversimplifying this, but sometimes that's the first thing to check. How's your tire pressure? Is it correct on all tires? Are all tires the same size, make, and brand?
11-02-2013, 06:18 PM | #4 |
The Niner
Are the springs sitting in the pockets ok?
"A good racer is one whose head is in communication with his balls." - Richie Evans 1970 C/20 - 402/TH400/3.54s - 74K miles 2003 GMC Sierra 2500 - Wheatland Yellow Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183 Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/ |
11-02-2013, 06:36 PM | #5 |
i've had close to 25 of these trucks over the years almost all had tweaked frames it is a very very very common issue with chevy trucks
11-02-2013, 08:58 PM | #6 |
Not an uncommon problem, but was it even be4?
11-02-2013, 09:18 PM | #7 |
maybe drive it for a couple of days and see if one side settles... it may just need to seat into the pocket.
71 swb 350/4sp manual 5/7 static drop |
11-02-2013, 09:43 PM | #8 | |
11-02-2013, 09:47 PM | #9 | ||
All the springs seem to be seated properly..... It was crooked before- the pics I took at the meet we had a few weeks ago, before I did any lowering, had it sitting funny then. I've got a buddy with a decent sized body shop. I might see what he wants to put it on the rack to see what's up. Always something.....
11-02-2013, 11:15 PM | #10 |
I had a tweaked frame. I found the lowest spot on the rail, jacked it up and put a jackstand in that spot and left it overnight. It took an 1.5"*out and got all 4 corners to within a .25".
Hope it's as simple to fix for you. |
11-03-2013, 06:20 AM | #11 |
That sounds like its worth a try. Boy, that'd be awesome if it worked. I don't like this truck sitting crooked.
11-03-2013, 08:15 AM | #12 |
Tot Roddin'
Here's the measurements from my 69 before and after drop (4.5/6") and after a wheel change (15" to 20"). You can see that even my truck isn't 100% "level".
Was your measuring surface level? Before the drop: Driver's Side Front: 33 1/2" Driver's Side Rear: 33" Passenger Side Front: 33 1/4" Passenger Side Rear: 32 7/8" After the drop: Driver's Side Front: 28" Driver's Side Rear: 29" Passenger Side Front: 28 1/4" Passenger Side Rear: 28 3/4" After the new wheels (4/3/10): Driver's Side Front: 28 7/16"" Driver's Side Rear: 29 5/16" Passenger Side Front: 28 1/2" Passenger Side Rear: 29 5/16"
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
11-03-2013, 04:52 PM | #13 | |
I am doing all my measurements on a finished concrete floor in my garage so its pretty level.
11-03-2013, 09:28 AM | #14 |
I am a Referee of life.
Don't put a level on your house.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
11-03-2013, 10:25 AM | #15 |
LOL- this house is good..... the last one, not so much. I found that out when I was working on some finishing trim.
11-03-2013, 11:24 AM | #16 |
Originally Posted by PanelDeland
Don't put a level on your house OR a square! |
11-03-2013, 11:36 AM | #17 |
Registered Cruiser
It cost $250 to have my frame straightened. One of the horns was tweaked pretty bad. It was money well spent.
I intend to live forever. So far, so good. |
11-03-2013, 04:53 PM | #18 |
I might try the overnight on an stand first, failing that, its off to see my man at his shop. If these frames are so jakey, how are guys not twisting them into pretzels with built engines?
11-03-2013, 05:22 PM | #19 |
Moderator
The frames arent jakey, that's just what 40 years of use does to a truck, lol.
11-03-2013, 09:50 PM | #20 |
Yeah, but I want another 40!
11-05-2013, 07:44 PM | #21 |
I wouldn't think it is a frame issue, your measurements were very close before you dropped it so I would check that the springs are in the pocket completely.
11-05-2013, 08:22 PM | #22 |
Here is a before shot- this is before any lowering, which to me, takes out mis-seated springs as the issue-
Funny how the truck beside mine (the 66) is in a sympathetic lean on the passenger side.... And here is after the front drop- I haven't got one of it with the rear done yet but it still sits the same.
11-06-2013, 03:55 PM | #23 |
Mine leaned like yours, i added 1/2" block to the high side between trailing arm and axel. Evened out my lean quite well.
Also you can try and swaping the springs from side to side, this might help. |
11-06-2013, 03:59 PM | #24 |
Maybe a very large fella drove it for a long time?
Could be a lot of things. Might not even be the frame. How do your cab and core support mounts look?
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
11-06-2013, 04:04 PM | #25 | ||
Seat feels pretty good, And replacing the coils would have fixed tired parts I'd think. The cab and core mounts look pretty solid but I can check them again. I'd think if one was bad enough to cause that lean, I'd feel or hear it when riding (and I've not). Thanks guys.
