Nv3500 an easy swap.... A big no no.....!
I put an nv3500 behind a zz4 crate motor and blew the tranny apart....
Re: Nv3500 an easy swap.... A big no no.....!
I followed a bunch of you guys on here and decided to do the swap.
First off, I took a lot of different ideas from a few members and put together the best ones. 1.Nv3500.... 2.Driveshaft from a 95 swb chevy 5-speed...59 1/2in. Fit perfect with a rear conversion u-joint. 3.Pre-assembled master and slave cylinder....extended push rod 1-1/2 and drilled pivot 2-1/2in from pivot on clutch pedal. 4. Tranny mount Pretty much a basic swap. Not knocking anyone's install. Just saying if you have any horsepower, this is not the swap for you. If anyone needs questions answered for this swap I'd be glad to help....! |
Looks like it's time for a NV4500
I'm considering an nv4500 but worried about the overall size. it either looks too tall or deep from the pics I've seen of one.... Dunno if I'd need to modify the tranny tunnel or if it'd hang to low for my truck with it being lowered 5" front and back... Has anyone seen a nv4500 in a c10 and could you provide pics?
Keep this thread going for everyone that wants a 5-speed with a big motor....! |
![]() Join Date: Apr 2012
3500, 3501....whatever it takes.
Sorry dude. |
i saw what you did there.
Give it up and get a TREMEC
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
I did that with the 3500 in my 93 s10 4x4 with a 4.3 if a v6 can break it then for sure a v8 they are real cheap transmissions not very good.
1976 k20, 350 built, 44/14 axles 1968 c10 6.5 turbo diesel,t5 trans 1977 gmc c3500 dually, crew, 4-53t, 5&3 trans http://67-72chevytrucks.com/vboard/s...d.php?t=591188 |
A tko 500 is probably gonna be my best bet or put my th400 back in....!
2WD Jimmy
![]() Join Date: Mar 2005
From the pic it looks like your clutch grenaded... or your flywheel.
Surprisingly the clutch and flywheel were unharmed... The input shaft was still stuck in the clutch disc and was also still lined up with the pilot bearing....! GO FIGURE...!
Wow thats some pretty good carnage! I've got a spare muncie M20 4 speed that needs to be rebuilt that I'd sell ya!
![]() Join Date: Oct 2009
Can you share what was happening (just driving, burnout, towing, etc) when it grenades?
Just getting on it...1st and 2nd went fine...hit a hard 3rd pulled to about 6 grand and blew apart...! Got a pretty good bruise from the shifter on my leg....!
#15 |
This engine tore up an m22 Muncie as well.... It's rebuildable....!
#16 | |
BlahBlahBlah
If it tore up a real M22 there was a problem inside the trans already.
#17 |
#18 |
Hope mine holds up behind my 4.8...
72 C10 - Multicolor, 4.8 ls, NV3500. Sold 72 K5 - Under Construction |
#19 |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Hundreds of millions of miles have been put on those transmissions behind 350s. Its a great transmission. GM wouldn't have put it in their trucks if it was prone to fail. They'd have been paying through the nose on warranty repairs.
Only when you pair it with an engine that puts out more torque than the trans was designed for do you run into these issues. That, or pure abuse. Obviously the ZZ engine the original poster has is much more powerful than a TBI 350 which the trans was intended for. I can't imagine putting an NV4500 behind a ZZ engine. They shift very crudely. Heavy duty ? Yes. But, sporty shifting they're not. |
#20 |
Oh,you can't buy that new
![]() Join Date: Apr 2000
I know it's two years later , but our NV3500 was drag raced occasionally, and towed a few things ,and held up well for 300,000 miles. Then it picked up a strange noise. kept changing fluid at 20K, and it made it another 100,000. truck ran in the 15's, but a 350TBI is no torque monster.lol
"been there, done that, ruined the T-shirt". 2007 LBZ GMC Sierra, ECSB 2006 LM7 RCSB Silverado 98 Vortec project. 94,3500,6.5L 4L80 81 SWB GMC POS finally gone ![]() 73 Pinto, stock, w/CragarSS's-eww ![]() 84,C10 SWB-Yella,stock 86 K10 SWB-Red, hopped up 305,4/S LOTS of Cummins trucks. |
#21 |
makes me wonder what the OKC farmtruck is running for a tranny
1969 Chevy C10 2wd stepside longbox |
#22 |
Ha ha. This thread reminds me when I put a t50 5spd in the camaro.
I babied it all summer then one fall nite I dropped to second an gave it some beans....same results. Lucky I had next to nothing in the swap. But now it runs a no ring sag.it sux.
81 camaro 355 4/spd 342 posi my first love ![]() 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
#23 |
#24 |
I'm planning on a nv3500 swap into my gmc, not behind a zz though staying with the 350. Looking to cruise for right now
Posted via Mobile Device |
