Old 11-03-2013, 05:49 PM   #1
57chevyman
57chevyman's Avatar
passenger door lock?
hey everyone, id like to change my passenger door handle to a locking handle. Of course I want one key that works for both doors, so I guess the easiest way to do it myself is to get a new set of locking buttons.... are the door handle buttons easy to swap?
I found this on ebay $80 for the pair including shipping. anyone know of a less expensive source?
http://www.ebay.com/itm/1955-1956-19...ff3be9&vxp=mtr
Frank
1957 Chevy 3100
2000 Silverado z71 SOLD
2012 Ram 1500 Quad Cab
1992 International 4700
57chevyman is offline   Reply With Quote
Old 11-03-2013, 07:43 PM   #2
Stepside Jim
Re: passenger door lock?
As long as the original and the aftermarket handles are basically the same I found the conversion to putting the locking mechanism to be very easy and straight forward.
I mention the original and the after market being the same because I bought new handles and locks from Classic parts, it was just a matter of removing a snap ring and a couple of parts get changed. So I can't speak for the originals, but the aftermarkets worked great.
Jim
Stepside Jim is offline   Reply With Quote
Old 11-03-2013, 07:57 PM   #3
57chevyman
57chevyman's Avatar
Jim
thanks Jim. i do have the original door handles on there. its funny that they bothered to make the driver door lockable and not the passenger door
Frank
1957 Chevy 3100
Old 11-03-2013, 09:26 PM   #4
sqrlnts
My local locksmith keyed both mine to the same key for $40. If you can score an additional cheap cylinder you may come out ahead using old stuff.... Just a thought.
sqrlnts is offline   Reply With Quote
Old 11-03-2013, 09:38 PM   #5
55metalmonkey
Before you change out the lock try to push the passenger door latch handle down (from the inside) until it clicks and try to open the door from the outside. The passenger door lock is incorporated into the handle and locks when its pushed down vs a pull on the door which is what everyone is use to.... Just in case you didn't know how it worked.... took me a while to discover this
55metalmonkey is offline   Reply With Quote
Old 11-03-2013, 10:08 PM   #6
57chevyman
57chevyman's Avatar
Smile Re: passenger door lock?
I never thought of that! ill try that and see what happens
Frank
1957 Chevy 3100
Old 11-03-2013, 10:20 PM   #7
57chevyman
57chevyman's Avatar
Thank you! just like you said, it does lock from the inside when I push the handle downward
I may eventually put a lock in that handle so that I can unlock it from the outside... but its good to know I can lock the door now!
Frank
1957 Chevy 3100
Old 11-03-2013, 10:43 PM   #8
55metalmonkey
No problem, like I said it took me awhile to discover that as well. I was 1 day away from ordering a complete lock set for $100 bucks
Old 11-03-2013, 11:05 PM   #9
55metalmonkey
Oh, one more thing I haven't tried yet and am unsure of is if you can set the lock with the door open and then close it. I've only ever locked it with the door already closed.
1957 chevy pu, door handle, door locks
