Old 11-04-2013, 11:54 PM   #1
AustinBelair
What size sockets do I need for front suspension swap?
I'm going to a salvage yard that is an hour away to get all the suspension off of an 80's pickup or Suburban and I already have probably 100 pounds of tools packed. is it all pretty standard sizes? I am removing:
A-Arms both sides top and bottom with spindles etc attached
All steering parts
Sway bar and brackets if any
Power brake booster and lines if needed
Possibly the steering column and other parts as possibly needed or wanted.
I don't have access to a truck to see or know the sizes I need.
Thanks guys!
My mother is a recent cancer survivor and this truck build is for her
AustinBelair is offline   Reply With Quote
Old 11-05-2013, 12:31 AM   #2
Captainfab
60-66 Nut
Re: What size sockets do I need for front suspension swap?
If you take sockets from 7/16" thru 15/16" that will cover everything except for the balljoint nuts. I don't remember offhand what size those are, but you can usually get a crescent on them. I want to say that the lower nut takes a 1-1/8" wrench, but I could be wrong.
Old 11-05-2013, 01:02 AM   #3
AustinBelair
Thanks, Captn! You reminded me to find my pickle fork!
Old 11-05-2013, 08:26 AM   #4
hd74
what do have to get the rivets off of sway bar.i have used cordless drill with cobalt bits ,and hammer and chisel. Sometimes they can be a bear
hd74 is offline   Reply With Quote
Old 11-05-2013, 11:05 AM   #5
scottofksu
scottofksu's Avatar
How about some chain and a padlock to isolate the coil spring?
I recently spent way to much time in our local pick-and-pull trying to do this on a 79 Chevy. One thing I found is that you might want to take a cordless drill with a bit small enough to drill out the rusted cotter pins... I ended up getting the center and drag link, but I got stuck on the lower ball joints as I as my crescent wrench was rounding the lower ball joint castle nut. I ordered two sockets (a 15/16 and a 1") and neither fit and I couldn't find any information on the internet about what size socket I needed (thanks Captain, now I know!)... When I finally went back to get the spindles they had crushed the truck the day before...
Good luck! Be careful!
Travis' Tribute Truck - 65 C10 Frame Up Restoration
http://67-72chevytrucks.com/vboard/s...d.php?t=495073
scottofksu is offline   Reply With Quote
Old 11-05-2013, 02:31 PM   #6
suxtobu65
suxtobu65's Avatar
Pitman arm is 1 5/16" socket, unless you plan on taking the steering gear box too... lol
"Sucks to be you" Suxtobu65
suxtobu65 is offline   Reply With Quote
Old 11-05-2013, 07:33 PM   #7
McCoyAZ
McCoyAZ's Avatar
Wouldn't it be easier to have them just cut the front end off and load it in your truck?
McCoyAZ is offline   Reply With Quote
Old 11-05-2013, 09:39 PM   #8
AustinBelair
Okay we're back and got a load today. I think we got a good deal. My brother and I got from an '84 or '85:
Front upper and lower A-Arms Left and right
Spindles
Springs
Calipers
Rotors
2 newer brake lines
All of the steering parts and components
Steering gear box
Power brake booster from a different vehicle
All for $110 and they pulled the parts.
Old 11-06-2013, 01:29 AM   #9
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
having them pull the parts was probably worth the $110!
