11-06-2013, 10:27 AM | #1 |
70' k/20 first restoration help
This truck means a lot to me and its been in my family since new so I want to do it right and honor the truck. And it's the first truck I ever drove.
My dad purchased this truck sometime in the early 90's from his 2nd cousin who has since passed. Its certifiably all original aside from the paint. Its a 1970 k20 with a 292 sm465 imguessing and factory lock out hubs. 214,xxx on odometer and it runs. Needs very little sheet metal wise. My question is what is the proper way yo restore the frame? Blast without disassembly or take it completely apart? Pic: |
11-06-2013, 01:33 PM | #2 |
Re: 70' k/20 first restoration help
To do it right you need to take it apart.
11-06-2013, 01:41 PM | #3 |
11-06-2013, 01:47 PM | #4 |
the way I did mine was take the front clip off, motor and trans out, along with core support, then take the cab off (4 bolts, fuel line, wiring) then take the bed off (6 bolts, wiring) then your down to a rolling chassis. the next step is up to you, I did mine the "right" way in my opinion, I took the front end out, and glad I did because it wasn't hard at all, 3 bolts on each of the frame rails, brake lines, then shocks. now its ready to blast, all you have is a bare frame and the rear end parts, axle, springs, etc. But the way I did mine was by taking the skidsteer and flipping the frame upside down to blast and paint it. I think this was a good way to do t because you can get everything underneath when painting it so it looks good when someone looks under the truck, and any missed spots will be on the topside where nobody will ever see. this step is completely up to you. I blasted to bare metal, etch primer, then flat chassis black paint (a lot of guys use por 15, the rust converter, not a big fan of this though just my opinion) remember though, the disassembly is easy! reassembly... not so much haha. that's how I did mine, hope this helps, hopefully someone else will chime in also. oh, by the way, slick truck! wish it was in my driveway
11-06-2013, 01:48 PM | #5 |
I just saw your reply, and no I didn't take the factory rivets out, way to much work, and I think they hold better than the bolts you would replace them with. I let mine in and it looks great!
11-06-2013, 02:10 PM | #6 | |
I saw one build thread where someone had taken the fram apart and re assembled with some grade 8 bolts and i didnt know how good of an idea that would be? I plan to blast the frame and use and off brand por 15, a chassis paint thats supposed to be a rust isolator/inhibitor. I'm going for good corrosion resistance and something that holds up good as I really don't want to do it again haha! Also what's the best blasting media for this? I was thinking about getting harbor freights 20lb blaster and some walnut hull media but I'm very open to some experienced advice! |
11-06-2013, 06:16 PM | #7 |
SWB 4x4 Collector
You can used sand/black beauty for frames, it works faster. Walnut would be more for sheetmetal
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
11-06-2013, 10:44 PM | #8 | |
11-06-2013, 06:29 PM | #9 |
Is black beauty safer than sand is? I know sand makes ozone gas
11-06-2013, 06:38 PM | #10 |
never heard sand creates ozone. and only the state of california would have a problem with that anyway. It does cause silicosous (sp?) which leads to lung problems. I dont get anywhere near sand blasting without a mask.
11-06-2013, 10:38 PM | #11 |
i used black diamond (same thing im guessing?? except this stuff didnt have silicon in it) but anyways, the por15 is your choice, it supposed to be a good rust inhibitor, however im not sold on it yet, up to you man! and yeah i have seen a thread, i think it was somewhere in the 4x4 section where a guy used grade 8's in his frame during reassembly and he said they work good you want to remove a crossmember and what not but he said he had to tighten them all after about 3-6 months of use. i suppose you could get around this with lock nuts and some red loctite, but i just stuck with the factory rivets becasue the way i look at it, is 1. they cant loosen up and 2. GM musta did something right back in 1970 if theyve held up this long, so why change a good thing. i have the same mentality as you, do it right once so you dont have to do it again. so im confident in my rust protection by leaving the crossmembers and rivets in place. i think the rivets look cool too!
11-06-2013, 11:36 PM | #12 | |
2004 GTO H/C/I/E 6mt 430hp 2001 2500HD 6.0 Gasser Leveled on 33's 73' C10 SWB 5.3 L59/4L60E 4/6 Dropped 70' K/20 "Family Heirloom" 292/SM465/NP205 - Project Last edited by Skid99; 11-06-2013 at 11:48 PM. |
11-06-2013, 11:19 PM | #13 | |
Thanks again for the replies.
http://www.harborfreight.com/20-lb-p...ter-68994.html Got some pics: SPID: Front Diff 4.55 gears im guessing by the tag, its a dana obviously buy idk which one(Please help me Identify): exposed (large) knuckles -thank god: Rear end (Eaton unit): Last edited by Skid99; 11-06-2013 at 11:31 PM. |
11-07-2013, 09:46 AM | #14 | |
11-07-2013, 09:54 AM | #15 |
Now thats a bumper!
1970 GMC 1500 stepside 1972 GMC Jimmy Custom 2004 Chevy Colorado 1989 Swb Silverado 1972 Aj's Stormer |
11-07-2013, 10:07 AM | #16 |
Dad loved to make bumpers Lol.... Its an air tank lol
2004 GTO H/C/I/E 6mt 430hp 2001 2500HD 6.0 Gasser Leveled on 33's 73' C10 SWB 5.3 L59/4L60E 4/6 Dropped 70' K/20 "Family Heirloom" 292/SM465/NP205 - Project |
11-08-2013, 12:08 AM | #17 |
He knew what he was doing!
project: "my happy mess" |
11-07-2013, 12:39 AM | #18 |
I have seen builds here where none of the cross members are removed, and i have seen where all the rivets are removed and all the pieces individually sand blasted and repainted, If you do remove cross members you need to be using Grade 8 hardware to bolt it all back together, i have had little luck finding loc nuts stronger than Grade 5 but they may be out there somewhere. I do think that if there was enough surface rust on the frame that it could migrate between the metal at the rivets and possibly loosen up but i think thats a pretty extreme situation, i'd say 95% don't remove the cross members.
So you know you are gonna have to start a build thread right??
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
11-09-2013, 09:46 AM | #19 | |
11-07-2013, 12:47 AM | #20 | |
From the little I can see of yours, it looks like, if gone the route I had, yours would clean up Really nice.
11-08-2013, 09:48 AM | #21 |
Nice truck.
Am I wrong in thinking that the paint is not medium olive and the front axle should be closed knuckle?
11-08-2013, 09:50 AM | #22 |
Yeah it was repainted in the 90's and from what I've researched it should be the short, closed knuckles... maybe its a 70 1/2??? Idk.
11-08-2013, 10:27 PM | #23 |
Consider yourself fortunate that its not a closed knuckle and don't worry about it.
11-09-2013, 09:30 AM | #24 |
thats what i was thinking!
11-09-2013, 09:42 AM | #25 |
You will spend more time removing the rivets than you will doing all of the rest of the frame resto combined. No point in removing them IMO
