Old 11-07-2013, 11:43 PM   #1
rs74
rs74's Avatar
Heat duct issues.
Since I bought the 85 k30 I have been wondering why there is only one duct in the dash not including the defrost duct. They had a custom deluxe dash bezel that had no vent in it stuck in the dash pad eliminating two vents. The one buy the headlight switch was covered up by a piece of metal. This is an A/C truck.
I tore the glovebox and dashpad off tonight to find that someone had taken the top half of the duct work out. So all there was is defrost and floor. There was air blowing on the underside of the dash the way they had it set up. So I am taking the needed pieces from another cab and putting it back together the right way. Oh and there was a white plastic clip that holds a threaded rod that goes to the blend door. The white plastic piece was missing so fixed that too.
What I am wondering while putting this back together is what are you guys doing for the big gap where the defrost duct hooks to the main box. Are you putting tape around it to seal it off so you get max airflow through the defrost? Here is a pic of what I am talking about. Both my K30 and K10's were like this. I can drop the defrost duct down but I would have to unbolt it from the dash so it can slide down. But if I do that then I don't know that the defrost ducts will blow air up through the dashpad.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 11-08-2013, 07:21 AM   #2
79Betty
79Betty's Avatar
Re: Heat duct issues.
Mine's got gorilla tape. Black so not as noticeable.
When in doubt, throttle it out!
1974 Chevrolet Custom K20
2005 Ford Ranger Edge
1985 Chevrolet Custom Deluxe C10
79Betty is offline   Reply With Quote
Old 11-08-2013, 10:09 AM   #3
rs74
rs74's Avatar
I was suprised to see that much gap right there. Everything else seems to have a fairly tight connection on it.
Roy
1987 R10 shortie
Old 11-08-2013, 05:14 PM   #4
motornut
78K & 79C Jimmys
motornut's Avatar
I've seen that gap taped before, but can't you loosen and move the box up?
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 11-08-2013, 08:32 PM   #5
rs74
rs74's Avatar
The lower box is bolted to the firewall. I am not sure if there is enough play if you loosen it and try to slide it up.
Roy
1987 R10 shortie
Old 11-08-2013, 09:55 PM   #6
motornut
78K & 79C Jimmys
motornut's Avatar
there is slight play when loosend up
John
Old 11-08-2013, 10:09 AM   #7
Rubble
I just finished replacing the heater core on my crew last month,had all the ducting out to clean mouse sh&t out.I have the same gap in it,most of my others do to & it doesn't seem to affect the airflow on defrost that bad anyway.Had a morning two days ago of -20 deg C & it cleared windshield great!! I replaced the fan motor too,that really helped airflow...that and getting critter nests out!!
1977 Chev C30 454/465/14ff DRW
1974 Chev C20.350/465/14ff
" Rock n Roll ain't noise pollution"
Rubble is offline   Reply With Quote
