Old 11-09-2013, 05:44 PM   #1
rickairbound1
Kick Panel Vents, Left vs. Right
Guys,
I forgot to mark my left and right kick panel air vents on my 72 C10 when I took them off. They are clearly different on the back side but I can't tell which one is the left or right. Appreciate any assistance.
Thanks, Rick
rickairbound1 is offline   Reply With Quote
Old 11-10-2013, 10:04 AM   #2
Daddy Brim
Daddy Brim's Avatar
Re: Kick Panel Vents, Left vs. Right
Hope this helps. First pic is the left one, second is the right one.
I'm sorry I called you stupid. I thought you knew already.
67 C-20 Custom Camper
68 Nova 396 it does wheelies
2005 Buick Century the one the wife drives
1989 Toyota Tercel to drive when I can't put gas in the first 2.
Daddy Brim is offline   Reply With Quote
Old 11-10-2013, 05:36 PM   #3
rickairbound1
Thanks DB
Old 11-10-2013, 10:46 PM   #4
DWilbur
Daddy Brim
Those vent look new. The one in my truck are old and the rubber is missing. I have not been aboe to find new ones.
DWilbur is offline   Reply With Quote
Old 11-11-2013, 12:52 AM   #5
Vova
Speaking of vents, how do you remove them?
Vova is offline   Reply With Quote
Old 11-11-2013, 09:04 AM   #6
Daddy Brim
Daddy Brim's Avatar
On the inside of the vent the top shaft is spring loaded. Pull down on top shaft, tilt and it will come right out.
Old 11-11-2013, 10:59 AM   #7
Andy4639
Old member
Andy4639's Avatar
Wink Re: Kick Panel Vents, Left vs. Right
On a non AC cab I don't think it matters which one is which since they both are manual. Not 100% sure of this but can't see why it would matter though.
AC cab the passenger side is vacum operated so it's obvious which one it is.
U can buy the new gaskets from most vendor on here.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 11-11-2013, 08:50 PM   #8
Vova
Thanks, I was pushing up
Old 11-11-2013, 09:01 AM   #9
Daddy Brim
Daddy Brim's Avatar
Originally Posted by DWilbur View Post
Daddy Brim
I replaced the seal. you need to drill out the rivets replace the seal and put in new rivets.
Old 11-11-2013, 07:42 PM   #10
Cordless57
Where can I buy a new vent? My drivers side vent was replaced by a plastic bag stuffed into the vent opening.
Cordless57 is offline   Reply With Quote
Old 11-12-2013, 11:25 AM   #11
Andy4639
Old member
Andy4639's Avatar
I've never seen a new one. More than likely u will have to buy a old used one.
Old 02-02-2020, 08:08 AM   #12
Rogerlumibao
Exclamation Re: Kick Panel Vents, Left vs. Right
Looking at replacing mine and just ran into these online, they are in back order but looks like your able to find em on Ebay or other sites depending on who had them now. this is from LMC.
Rogerlumibao is offline   Reply With Quote
Old 02-02-2020, 10:01 AM   #13
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Kick Panel Vents, Left vs. Right
I found them at LMC also Manes carry them as well.
Old 02-02-2020, 03:05 PM   #14
HO455
HO455's Avatar
I replaced the seals on mine. Here is a link to my repair thread. Scroll down to post 232.
https://67-72chevytrucks.com/vboard/...698377&page=10
RIP Bob Parks.
Old 02-02-2020, 11:46 PM   #15
lutronjim
I replaced seals on mine. When trying to drill out rivets, most would just spin. Solved by using dremel to cut off head - much faster
lutronjim is offline   Reply With Quote
Old 02-03-2020, 07:53 AM   #16
notsolo
notsolo's Avatar
Instead of the 10 cent foam, I used silicone sheet, cut oval, pop rivet in place.
notsolo is offline   Reply With Quote
Old 02-03-2020, 03:12 PM   #17
lousyflyer
I have replaced the rivets with 8-32 screws and locking nuts and also used pop rivets with backup washers.
Either way works just as well. Just dont try the pop rivet method without the washers, as they tend to pull through the thin metal without popping. They make a special washer for this purpose. Save yourself some time and head to a real hardware store. Or you can order a bag of them from Grainger, like I did.
I think there's about 480 washers left in my bag.
lousyflyer is offline   Reply With Quote
72 c10
