Old 11-09-2013, 11:08 PM   #1
zicc1835
zicc1835's Avatar
control arms difference
can anyone tell me if there is any difference between 68 and 71 control arms ball joints ? spindles ? thanks
jz
zicc1835 is offline   Reply With Quote
Old 11-10-2013, 10:06 AM   #2
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Re: control arms difference
None. My 72 control arms were dinged up. I got some 68 control arms from a buddy and used new ball joints and they went right in. Also used new everything else as well as my ECE drop spindles.
Tom Vogel is offline   Reply With Quote
Old 11-10-2013, 02:27 PM   #3
zicc1835
zicc1835's Avatar
thanks thats good news i also have drop spindles for it at this point i am just collecting parts for the build
thanks again
jz
Old 11-10-2013, 11:28 AM   #4
primetime
primetime's Avatar
I was just researching the same question. looking at the LMC brochure the control arms are the same from 67-72 for a 1/2 T truck. there IS a difference for the part # of the ball joints. my guess is that whatever spindle you use the ball joints needs to match that year's spec. JUST MY GUESS, because I'm still researching it for my own project.
hopefully more knowledgeable folks can chime in too
1968 Chevy C10 swb fleetside
2005 Chevy Silverado crew cab (SS)
1977 Goldwing cafe racer
1977 Chevy nova (first car/ first love)
primetime is offline   Reply With Quote
Old 11-10-2013, 02:29 PM   #5
zicc1835
zicc1835's Avatar
please LMK or share if you find any other info
thanks
jz
Old 11-12-2013, 12:36 PM   #6
snipescastle2
snipescastle2's Avatar
Talking Re: control arms difference
here are the control arms I have on my '71 swb. they are different from the ones I seen in the manual, no provision for a lower bump stop cushion. May be from a 67' model, but the ball joints fit and the 71' spindle bolted up just fine.
hope this helps
Ben Smith
snipescastle2 is offline   Reply With Quote
Old 11-12-2013, 05:53 PM   #7
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
I should probably edit my first reply. No differences that Matter. Bump stops could be different, I think mine were shorter. However, ball joints and spindles Will fit fine.
Old 11-12-2013, 07:29 PM   #8
tlcrz1972
tlcrz1972's Avatar
The geometry of them are the same.
But the difference is that the turn stop surface is different.
The '71-'72 disk spindle knuckle has an angled surface that matches an angled surface on the lower a-frame (control arm)
'70 and earlier have a different surface that the drum spindle knuckle stops against.
1972 Chevrolet Cheyenne LB 1/2 ton finished restoration/rebuild 1995 350 throttle body FI, 4L6E (running on modified GM wiring harness) 3.08 posi rearend, factory A/C on 134A, p/s, p/b, late 70's power windows and locks and cruise, speakers in the dash + 6x9's behind the seat, factory tilt, 40 gallon fuel tank in the bed with integrated tool box, air assist bags on the rearend, sway bar up front and much more.
1972 chevrolet SNB finished 2002, 350 TB FI, TH400, factory A/C, p/b, p/s, (FOR SALE)
1969 Chevrolet 1 ton in work, home made PTO dump bed extended frame, 350 CI ,
1972 Chevrolet 3/4 ton suburban future project
1972 Chevrolet 3/4 ton p/u maybe a project one day
1966 Toyota Landcruiser my playtoy
tlcrz1972 is offline   Reply With Quote
Old 11-12-2013, 10:54 PM   #9
zicc1835
zicc1835's Avatar
thank you for this info thats interesting so do you know if the 70 and below and in my case i have a 71 with disc and intend to use the 68 C arms will the angle difference if you know cause a problem
thanks
jz
Old 11-13-2013, 07:57 PM   #10
tlcrz1972
tlcrz1972's Avatar
I believe it will decrease your turning radius.
thanks
jz
Old 11-13-2013, 10:16 PM   #11
zicc1835
zicc1835's Avatar
It's gonna be a while till I start this build I will report back when I do thanks to all for the input
Jz
Old 11-12-2013, 11:01 PM   #12
zicc1835
zicc1835's Avatar
Tom you may be able to answer the question i posed to tclrz1972 you have any issues with the two different angles
thanks
jz
Old 11-13-2013, 09:46 AM   #13
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
I removed mine to accomodate the adjustable ones that came with my ART bag setup.
