Old 11-10-2013, 05:34 PM   #1
Fldawg
Fldawg's Avatar
Tired of my long tube headers!!!!!
Hey Guys, just what to get everyones opinon, when i built my truck bought a set of cheap stainless headers and i mean cheap, well now i want to change them out for shorty headers, looking for comments on which are good and bad and will fit angle plug aluminum heads and also clear everything, i've seen a set of sandersons on here just wondering if there is any more out there,
Thanks for any info
Fldawg is offline   Reply With Quote
Old 11-10-2013, 05:58 PM   #2
Drewski23
Re: Tired of my long tube headers!!!!!
why do you want to replace them with shortys? just curious
Drewski23 is offline   Reply With Quote
Old 11-10-2013, 06:08 PM   #3
Fldawg
Fldawg's Avatar
They where not very good quality and i had to do alot of fitment issues, bending for plugs to clear, motor mount and brake line issue
Old 11-10-2013, 06:18 PM   #4
71K20chevy
71K20chevy's Avatar
Shorty headers are almost pointless. Long tubes are where you get your power, so I'd suggest investing in some.
71 K20
64 GMC mud truck
71K20chevy is offline   Reply With Quote
Old 11-10-2013, 07:54 PM   #5
engineer_gregh
engineer_gregh's Avatar
I had these headers installed when the engine was rebuilt, the only issue I had is that they hit the lower control arm on the passenger side so one pipe had to be heated and bent in slightly to make them work. When I had new exhaust run from the headers back this past Thursday the shop I used recommended 3/4 length headers. Of course this was after a couple of thousand miles on the full length headers and old exhaust.
http://www.summitracing.com/parts/SUM-G9112
engineer_gregh is offline   Reply With Quote
Old 11-10-2013, 08:17 PM   #6
bigmac73
bigmac73's Avatar
the Headman headers I bought out of the LMC catalog, fit real nice and bolted right up
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 11-10-2013, 10:30 PM   #7
CaliLivn
Are they the full length or 3/4? I been looking at getting the 3/4 for my 72. Trying to get some opinions.
CaliLivn is offline   Reply With Quote
Old 11-11-2013, 09:02 AM   #8
GMCJOE
GMCJOE's Avatar
I have heard good things about these.
http://hedman.shptron.com/p/67-87-c1...-length-design
Joseph
Joe's 69 GMC
http://67-72chevytrucks.com/vboard/s...d.php?t=543253
1969 GMC SWB-350 SBC 700R4
2013 Ram 2500 CC Laramie Longhorn Edition-6.7 PPEI EFI Live CSP5 5” ProFlo Exhaust
GMCJOE is offline   Reply With Quote
Old 11-11-2013, 09:46 AM   #9
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
FWIW... Shorty Headers offer NO performance advantage over cast iron manifolds.
Tom Vogel is offline   Reply With Quote
Old 11-11-2013, 09:48 PM   #10
zeldman
zeldman's Avatar
I agree. Also shorties give you more headaches than cast iron manifolds.
2005 GMC K2500HD D/A
1993 GMC K1500
2011 Subaru Legacy.
2013 Subaru Outback
1970 C-10 2WD, SWB stepside, 292, TH350, PS, more rust than anything. God is my pilot.
zeldman is offline   Reply With Quote
Old 11-11-2013, 09:55 AM   #11
Fldawg
Fldawg's Avatar
i think i'm gonna go with the 3/4 lenght ones that hedman makes, i want to redo my exhaust anyway
