11-10-2013, 10:55 PM | #1 |
How to fish dome light wire up there?
Subject line is it in a nutshell, but I need to run both the cargo and dome lamp harnesses up to their respective locations.
I put a big washer around it and tried to "drag" it up with a strong magnet, but that went nowhere fast. I tried to send a wire down from the top hoping I could then tie it and drag my harnesses up, but didn't have much luck. Well, no luck to be precise. Anyone done this before and have a trick to share? Thanks!
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
11-10-2013, 10:57 PM | #2 |
Re: How to fish dome light wire up there?
Electricians tool called "fishtape". If you have a flexible end called a "leader' on it, it should work for you.
11-10-2013, 10:59 PM | #3 |
If that won"t do it you can tie some string to the end of the leader and "hook" it with another fish tape on the other end. Good luck!
11-10-2013, 11:06 PM | #4 |
Got it! Of course, right after giving up and posting, per usual.
Couldn't find my fish tape or my glow stick. I have both... somewhere. I fished some 14/2 house wire down FROM the dome lamp to the opening at the bottom of the B pillar, taped all my harnesses to it, and pulled it all up and out through.
11-10-2013, 11:08 PM | #5 |
#16876
I wish I could find it but Texas Firefighter made a video a while back. He used string and a blow dryer. I'll look around....
Posted via Stationary Device '71 Custom Deluxe C-20 402. '67 Buick Special 455. '49 Plymouth Special Deluxe. "I love that old car smell" Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs. |
11-11-2013, 03:13 AM | #6 | |
I used a fishing pole with a 1 ounce weight and no hook. Insert fishing pole into opening, release the line and dropped the weight down the rear pillar. Cut fishing line and tied it onto wiring harness and pull through. Eazy peazy! Keith |
11-11-2013, 07:13 AM | #7 |
Watch out for your cornhole !
11-11-2013, 07:23 AM | #8 |
nice video!!
11-11-2013, 09:44 AM | #9 |
Wire clothes hanger straightened out, tape string to hanger, attach string to wire to fish in, pull
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
11-11-2013, 10:53 AM | #10 |
Old member
I've used the coat hanger and also the house hold wire took out of the outer sheeve. It's stiff enough to stay straight but will follow the curve of the cab wall when it hits it. Takes a little bit to do but I've had very good luck using it in the past.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
11-11-2013, 03:12 PM | #11 |
Thanks for posting.
11-11-2013, 07:22 PM | #12 |
Clever idea, though not sure it would work as well on our A or B pillars. Never hurts to have another tool in the old mental toolbox though, so thanks!
11-11-2013, 07:25 PM | #13 |
I am an electrician and have glow rods and fish tapes, so I used a glow rod. TO anyone not wanting to spend a lot of money, Harbor Freight had some rods simililar to glow rods. IIRC, they are around 2' long and screw together like rifle cleaing rods.
11-11-2013, 07:28 PM | #14 |
My first glow rod was left behind in my house, but the second one I bought from Home Depot. Terrible. Was made of fiberglass and as soon as it got bent it developed splinters, and glass splinters will ruin your day.
11-11-2013, 07:40 PM | #15 |
BlahBlahBlah
Hmm this thread reminds me I have to schedule my colonoscopy
11-12-2013, 02:16 AM | #16 |
11-13-2013, 06:29 PM | #17 |
The Niner
I'm having mine on Friday..woohoo!
"A good racer is one whose head is in communication with his balls." - Richie Evans 1970 C/20 - 402/TH400/3.54s - 74K miles 2003 GMC Sierra 2500 - Wheatland Yellow Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183 Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/ |
11-12-2013, 03:52 AM | #18 |
String and compressed air does wonders. You'll be amazed at the routes you can fish a string thru with it.
