11-11-2013, 05:56 PM | #1 |
Vapor Canister for LS Swap
Is anyone using any kind of charcoal filter or vapor canister for their LS Swap? The smell of gas in my garage is a bit overwhelming. I'm using one of Boyd's Welding tanks under the bed, so space is at a premium. Most that I see are too large to mount under the bed. Any ideas?
11-11-2013, 06:06 PM | #2 |
meowMEOWmeowMEOW
Re: Vapor Canister for LS Swap
Everybody (most) except the Cali guys pull all that stuff off.
If the garage doesn't smell good, your using cheap gas!
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
11-11-2013, 07:16 PM | #3 |
Are there things with the tune that would/wouldn't render the vapor canister useful? In my s10 framed build, I left it in...but it's not on the road yet.
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
11-11-2013, 10:50 PM | #4 |
I always wondered about this as well but i don't have the original 05 when but i was wondering about using the one from my 91 since there's two lines one from the gas tank and then going up to the original throttle body could you not plumb that line to the new throttle body like the intake duct or something? Just a thought as i still haven't touched my 6.0 swap lately
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854 1988 IROC-Z Camaro - 305/T5 T-Top 1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850 1991 V2500 Suburban Silverado - Sold 1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423 2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold 2003 1500 Silverado 2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold 2005 Silverado 2500HD 6.6/ZF6 CC LWB |
11-11-2013, 11:04 PM | #5 |
meowMEOWmeowMEOW
There is the evap solenoid and the code it will throw if it were disconnected. Its usually turned off en-mass with the rest of the emissions stuff.
I don't like the idea of sucking combustible vapor through a hose the full length of my truck, into the engine bay and into the intake manifold. Same goes for EGR, don't like it.
11-12-2013, 08:00 AM | #6 |
What type of fuel lines did you use?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
11-12-2013, 09:21 AM | #7 |
I had all my emissions stuff turned off when I initially had the ecm flashed to remove VATS and stuff. I'm mainly looking for an idea to hook a hose from my rollover vent on my gas tank to some type of filter just to rid the garage of the strong gas smell. Fuel lines are -6 stainless braided.
11-12-2013, 09:32 AM | #8 |
Hook up an evap purge solenoide, vent and canister, let the pcm do it for you. That's what I plan on doing. I got my Evap canister from the engine compartment of a 99 burban, it had the vent attaced.
11-12-2013, 09:38 AM | #9 |
I have the original one on my 71 hooked up to the line from the tank to vent it, but left the other hose that used to go to the carb open. Works fine as a vent and no gas smell what so ever.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
11-12-2013, 05:24 PM | #10 |
meowMEOWmeowMEOW
If you just want SOMETHING to help with the smell, then just grab the evap off on a second generation (94+) S10. Its a square can about the size of a can of lighter fluid with a grounding strap ("sensor") and inbound line. Just plug your vent line into that (its just a box of activated cabon).
Ghetto-fabulous you could probably stick a few crushed charcoal brickets into an old PCV catch and hook it to the vent line. (But don't say I told you to)
11-13-2013, 12:11 AM | #11 |
I installed a canister and canister bracket and hose ends from a 1999 Tahoe. I mounted the canister behind the battery. I used the existing vapor line, just re-bent the end of the line and ran a hose to the canister. Then used the old fuel supply line as the feed from the canister to the engine. I just re-bent the line to the rear of the trans and connected it to the engine purge feed.
I bought a new replacement gas cap as the old one was leaking. No fuel smells and it even passes the evap leak test! Here are a couple pics of where I mounted it.
-Sean 1971 C10 - 5.3 LM7 + 4L60E |
11-13-2013, 02:21 AM | #12 |
Do you back into your garage causing the fumes to build up?
Custom Painter/Restoration Specialist 1965 GMC 3/4 Ton LB SOLD? 1964 Chevy El Camino in full restoration 1991 Chevy S10 288K+ miles 2nd Owner SOLD 2020 RAM 1500 Warlock |
11-14-2013, 10:33 AM | #13 |
I don't always back into the garage, so I don't think that would completely be the issue. I usually leave a window open to let some of the fumes out as well. Does anyone see any reason why I couldn't take some sheet metal and weld together a small box with a spot to hook a hose up, and fill it with activated carbon? Wouldn't this serve the same purpose as the large vapor canisters that you can buy?
11-14-2013, 08:29 PM | #14 |
You could do that, but I'm not sure how long that would last before you would smell the fumes again. The activated carbon would eventually get saturated with the hydrocarbons and start to "leak" by. If you added another port on your home made canister and vented it to the engine though the purge system, it would remove the hydrocarbons from the activated carbon. It would also help very slightly with gas mileage...
11-14-2013, 11:00 AM | #15 |
I am going to use charcoal from the "fish" store for in home fish tanks, they tell me that is the same and much less expensive.
What gas cap will fit my stock 78 pick up (new 87 tank & sender) that is NOT vented?
