ad speedometer
I want to run the stock ad speedo and I have a 700r4. what to do? do they make a cable that will work? trans is an earlier one with a gear in it
Re: ad speedometer
My cable in my 50 was long enough and threaded into the 700r4. Yes the make longer cables, but your will most likely work if its the stock length.
Re: ad speedometer
I also have a 700r4 ('89) but I think it is an electronic speedo connection. Can you change to the gear to use with the AD speedo? Thanks, Clay
