What is this?
![]() Join Date: Oct 2011
Re: What is this?
Yep! That is the kickdown switch for a THM-400 One side should have key hot power, the other side should get power when the gas pedal is fully depressed, sending power to the single spade connector on the side of the transmission which engages the kickdown solenoid inside the trans.
Re: What is this?
What colour are the wires for the original connection in the cab?
And if I have this, why do I have a vac modulator on the RH side of the tranny? |
Re: What is this?
that is the kickdown switch for the turbo 400 i think it has red and white wire ran to it.. the wire that goes down to the transmission is orange. if you dont have a turbo 400 you dont need it.. the turbo 350 and 400 both have a vacum modulator thats what causes it to shift .
4x4k30 if trouble was money i would have plenty |
Another Day, Another Dollar
Re: What is this?
Orange and white I think
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box "its hip to be square" ![]() |
Re: What is this?
THM-400 uses an electric kickdown whereas the THM-350 uses a detent cable aka kickdown cable. Both transmissions use a vaccum modulator as noted by 4X4k30, a modulator has more control over upshifts. Wire it back up and you will have downshifts again.
At the body shop.
Re: What is this?
Pull the shifter down. Isn't required.
" That didnt make it any newer " " Dont antique the equipment " |
Master Hater
Re: What is this?
yea the arm on my pedal won't even reach my kickdown switch.
1997 C1500 ECSB 4.3/NV3500 8.5 3.42 "This evening, all of you bleeding hearts... why don't just go ahead and hug yourself for the next 20 minutes or so, because there's a really good chance you're gonna be offended".- Captain Owen Honors |
Re: What is this?
I can't find the harness in the cab for the kickdown switch for the life of me.
The tranny still had the harness end with orange wire attached. Was only about 6" long. Found what I believe is the other end cut off up on the fire wall. Ran new wire to connect the 2 ends. Where should I be looking in the cab?! I'd really like to get this thing working. Truck is gutless and terrible on fuel..... ![]() |
#10 | |
Re: What is this?
Re: What is this?
The switch was there, but absolutely no wiring for it. At least not any I can find.
Where would the wiring typically be? |
Re: What is this?
i will look on my 79 tomorrow and see what i can find out for you
Re: What is this?
here is a pic of the wires going to it. they are orange and pink with black stripe
