Old 11-12-2013, 10:13 PM   #1
1 MPG
Gear ratio, tire size, and lift? 72 Suburban
I'm planning to install 35x12.50x15, 4 inch or six inch lift, and possibly 4:10 gears. I would still like good RPMs at highway speeds.
What's the factory tire size that came with 1972 4x4 Suburbans.
My current gear ratio is stock 3:08, 350 turbo transmission, and 350.
Let me know what works for you?
1 MPG is offline   Reply With Quote
Old 11-13-2013, 03:17 AM   #2
andrewmp6
Re: Gear ratio, tire size, and lift? 72 Suburban
A chart http://www.offroaders.com/tech/gear-ratio-chart.htm or if you want a calculator to play with http://www.pitbulltires.com/calculate.php
Old 11-13-2013, 08:27 AM   #3
1 MPG
Thank you for taking your time to send me this information! It is exactly what I was looking for. Now I need to figure out what the stock tire size was?
Old 11-13-2013, 09:28 AM   #4
Bigdav160
Bigdav160's Avatar
Do you have a SPID on the glove box door? Any tire options listed? I think a 31.5 inch diameter was close to stock on a 4x4
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 11-13-2013, 12:03 PM   #5
vectorit
What?
vectorit's Avatar
More than likely the OE tire spec is this:
L78-16.5-BB on/off road.
There were many different options for tires and wheel size, so check your SPID to see if it says what option it was ordered with.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 11-14-2013, 04:02 AM   #6
andrewmp6
If you want a easier one http://www.advanced-ev.com/Calculators/TireSize/ you put in the info on 3 and the 4th it will give you,Like your tire size gear ratio and speed it will give you rpm,Or tire size rpm gear and it will give you your speed.
Old 11-15-2013, 05:56 PM   #7
obijuan
this calculator is the best i have ever used:
http://www.grimmjeeper.com/gears.html
id go 410 gears with a th350 for all around cruisin town, pulling a boat, typical truck stuff. maybe even 373s for managing those rpm at 70 if your motor has some low end cajones. i had 36s and 373s on my dually and it was terrible, but i always had it loaded with something.
obijuan is offline   Reply With Quote
Old 11-15-2013, 08:54 PM   #8
1 MPG
I'm torn between 373 and 410. Lol
You guys all rock. I'm glad I became a member of this site.
Old 11-15-2013, 09:10 PM   #9
obijuan
410s it is.
Old 11-18-2013, 10:09 PM   #10
1 MPG
Do you think I should change my stock gears or look for used differentials?
I'm all most positive 308, 373, and 410s where the options for 67-72?
Old 11-18-2013, 10:26 PM   #11
swamp rat
swamp rat's Avatar
I have 4:10's (or is it 4:11's?) I have 33" BFG's and a TH350. I am at about 2600 at 60 mph the calculator says i should be at just over 2500.
What i did notice right away was the loss of acceleration from a stop in going from stock to 33's.
I think if you went to 3:73's you'd regret it.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 11-19-2013, 04:02 PM   #12
BigRed76
BigRed76's Avatar
I had 35's with 3.73's on my old '76 K10, with no overdrive and cruising rpm's down the interstate were perfect, and I never had much trouble accelerating from a stop but it always had good torque.
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
