Old 11-13-2013, 05:07 PM   #1
61K10
61K10's Avatar
transfer case mounting cushions
bought prothane cushions for my 61with the 221 t/f case. the sleeves id is bigger 5/8" not 1/2"---so just use bigger 5/8" bolts? how about 5/8" cap bolts (allen head)? box reads years 60-72. the one hole in the top of the x-member would have to opened up to fit a socket on the bolt head (thus the cap bolt). i also have 2 spacers that go on top of the mounting bracket.--stock? would have to be drilled also. thick cushions on top i would think? (my old ones were home made)
so what have you guys done?
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 11-15-2013, 01:03 PM   #2
Morgantown Mafia
Re: transfer case mounting cushions
Absolutely nothing wrong with opening up holes for larger bolts.I would use grade 8 fasteners.Thick bushing between transfer mount and xmbr. Thin on top.
Morgantown Mafia is offline   Reply With Quote
Old 11-15-2013, 02:14 PM   #3
61K10
61K10's Avatar
thanks for the reply---I ordered a set from lmc to compare. funny on e-bay my truck is not compatible, but my box says 60-85 or something. must have changed when the np205 came out?
1961 chevy K10
Old 11-16-2013, 03:10 AM   #4
JPBrecheisen
Up to you which way you want to go, but if you don't feel like drilling, you can probably get a pair of reducer bushings to slide inside the ones you have. I'd think you could probably get some for under $10. They're designed to drop down the I.D. of what you have. So you could find some that had an O.D. of 5/8 and I.D. of 1/2. Just push them in, and you should be all set.
Just an idea.
Maybe the ones from LMC will have you in good shape and you wont' need to do anything except install.
Good luck with it.
Jonathon
1960 GMC K1500 LB Fleet Side
1962 GMC K1000 LB Step Side
1988 Chevrolet C2500
JPBrecheisen is offline   Reply With Quote
Old 11-17-2013, 12:41 PM   #5
61K10
61K10's Avatar
thanks for the reply JP---I thought about different bushings also. (haven't looked for any yet) we will see what lmc's are.
1961 chevy K10
Old 11-21-2013, 12:49 PM   #6
61K10
61K10's Avatar
well i received my cushion from LMC and they are the same 5/8"s bolt. even the same company--prothane. guess i will use bigger bolts.
1961 chevy K10
Old 11-21-2013, 10:38 PM   #7
swamp rat
swamp rat's Avatar
You could call Wes at Classic Heartbeat, he builds these trucks as well as selling parts, he would probably have an insight to your problem, worth a shot.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
