11-15-2013, 11:25 AM | #1 |
5.3 swap ?s
I know this has been ask a lot, however I.ve never considered the task until now.
My son and I are strongly considering pulling the 350/350 combo out of the 69 and going with a 5.3 swap, with the classic look but the modern motor and drive train. Who has the best informative link on the forum that has done this with best results???? Thanks Donnie and Buck
Things happen for a reason! |
11-15-2013, 05:11 PM | #2 |
Re: 5.3 swap ?s
The best? Good luck on that one.
Go to the Engine, LS swap section…tons of info and some awesome swaps. In my opinion, it's a great setup…but takes some work and the "little things" add up and sometimes a pain. Having done three, I don't know if I'd do another. There's something simplistic, easy and comforting about staying with an old 350 setup. 350/700r4, 454/200r4 or something like that is appealing to me nowadays… I'm tired of working through all those little issues. Good luck! (The swap would give great bragging rights for your son!)
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold 1972 C10 5.3L/4L60E 12bolt 5Lug - Sold 1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!! 1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold 1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold 1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold) 2003 K2500HD 8.1/Allison1000/NP263 Last edited by OldCreek; 11-15-2013 at 05:23 PM. |
11-15-2013, 05:39 PM | #3 |
Old member
Re: 5.3 swap ?s
Donnie I'm fixing to swap a 6.0 in my 71. As stated go over to the LSx motor threads and look around. There are several.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
11-15-2013, 06:20 PM | #4 |
Re: 5.3 swap ?s
Be warned, the LS koolaid is delicious. Leak free, smooth, effortless power with 20+ mpg.
Stock they're great. In my Camaro, a stock LS1 with long tube headers and a tune ran within two tenths of my previous 383/Dart head/hyd roller engine. But once you start doing a few mods....the LS family really wakes up. Ls1tech has a conversions and hybrids section, all you need to know about a basic fuel injected swap you'll find there. Good luck and have fun! |
11-19-2013, 01:41 PM | #5 |
Re: 5.3 swap ?s
11-19-2013, 07:57 PM | #6 | |
Re: 5.3 swap ?s
I've got a 347 LS1 in a Camaro, and even with 2 passengers, a trailer, and the car stuffed full of gear (estimate 4300lbs total with trailer) I averaged 20mpg on Drag Week. With 4.30 gears nonetheless and a T56. I do the tuning myself and was running OLSD (open loop speed density) and even ran ~14.0:1 AFR all the time. At part throttle and transition the slightly richer AFR seemed to make the engine real happy as opposed to stoich. Anyway, I just picked up my 70 Stepper last month and have been cruising the L6 since. I'll be doing a 4.8 or 5.3 swap this winter. And a turbo...muhahaha!!! |
11-20-2013, 07:28 AM | #7 |
Re: 5.3 swap ?s
[QUOTE=Heavymetl;6372924]Only 15? That's interesting, no overdrive at all I assume?
QUOTE] Yes, it's the entire drivetrain "liftout" from a 2009 Silverado....5.3/4L60E, Speartech modified the stock harness, programmed the ECM/TCM....and I'm only 15 mpg's on the highway. I made (2) seperate 400 mile rount trips running 75 down the highway so I'm sure of my mpg's. |
11-20-2013, 11:56 AM | #8 |
Re: 5.3 swap ?s
to all the lsx guys on this site, its very much doable to avgerage 20+ mpg. first off a good tuner must found. the mail order tunes basicaly gets the car/truck to run/drive. any good tuner will take your setup, analyze the readings from the pcm such as afr, gearing, timing and other stuff and tune from there. trust me, in my first lsx swap, my 8'7 c10 with a 5.3/4l60e set up ran better than the 383/700r4, w/3000 stall, 11.1 to 1 comp. track times proved it. i spent a lot of moneyon that set up.
11-15-2013, 06:59 PM | #9 |
Re: 5.3 swap ?s
Lots of good info here http://www.lt1swap.com/
Real easy once you have done one.
1970 Short Wide 5.3 4L60E BlackBear tune 3:73 gears, Boyd's Tank 2.5 / 4 drop 5 lug disc brakes Vintage Air 18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear |
11-16-2013, 04:22 PM | #10 |
Re: 5.3 swap ?s
There are lots of good posts in the LS section. The guys on Powerblock did a LS swap and even though it was glitzed up for TV, there is a lot of useful information and links for things like fuel pumps and motor mounts as well as AN fittings and such.
http://www.powerblocktv.com/episodes...ls-engine-swap
Matt Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=672655 "Father thank you for the gathering of friends, Father we give thanks for all the choices we've made because that's what makes us who we are, let us forever cherish the loved ones we've lost along the way and most of all THANK YOU FOR FAST CARS!" |
11-19-2013, 12:13 PM | #11 |
Re: 5.3 swap ?s
Thanks guy's. I'll check these links out, humm the 700r4 swap might help me also..............
Donnie Good luck Andy.... Hey they canceled the car show at jr motorsports, that sucked.......... see ys soon bud.
11-19-2013, 04:51 PM | #12 | |
Old member
Re: 5.3 swap ?s
I will be droping mine off right before Christmas to have Hawks do the install and tune. Jr car show wasn't worth the drive for me again anyway's. Hope so man.
11-19-2013, 02:15 PM | #13 |
Re: 5.3 swap ?s
yes, i am curious about what the secret is to getting 20+ mpg....
11-19-2013, 04:02 PM | #14 |
Re: 5.3 swap ?s
20mpg a secret? I don't think so. A good tune and the right gearing. I have done 3 ls swaps 2 in chevy trucks and always gotten over 20+ mpg.
11-19-2013, 04:12 PM | #15 | |
Re: 5.3 swap ?s
Maybe tyou could enlighten me. I was under the impression that Speartech knew their ****. |
11-20-2013, 04:03 PM | #16 |
Re: 5.3 swap ?s
Wasn't trying to sound rude man just stating that 20+ mpg is easily possible. Has been for me anyways. I have hp tuners and have always done my own tuning. I am by no means a great tuner just learned from messing with my own stuff. These were 91+ octane tunes. I would get 22-23 mpg highway in both trucks. I think they both a 3.42 gearing. I also got about 26 mpg highway in my 92 fbody with a 5.3 swap.
11-19-2013, 04:08 PM | #17 |
Re: 5.3 swap ?s
I would advise to pick up a few books. I read them at night when I can't sleep.
Some people have swapped stock 5.3's for less than $2000, while others end up over $10,000. It seems with these LS motors, you spend just as much as you would rebuilding a small block, but you get so much more.
71 K20 64 GMC mud truck |
11-21-2013, 05:11 AM | #18 |
Re: 5.3 swap ?s
11-21-2013, 06:35 AM | #19 |
Re: 5.3 swap ?s
Looks great and your doing a killer job on the mag. Keep up the good work.
Eric Evans Queen City Shop Truck http://67-72chevytrucks.com/vboard/s...34#post6139834 66 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=543110 |
11-21-2013, 02:34 PM | #20 |
Re: 5.3 swap ?s
Thanks!
11-21-2013, 06:10 AM | #21 | |
Re: 5.3 swap ?s
that being said, I average over 20mpg all summer long on the local roads(35 - 50mph) MPG is 75% where you drive and how you drive.
Dave "... government even in its best state is but a necessary evil. Thomas Paine "It wasn't a lie, it was ineptitude with insufficient cover." Donald Draper (Mad Men) |
11-21-2013, 06:52 AM | #22 |
It's alsways something.....
Re: 5.3 swap ?s
The deal is that most of us do not have an accurate odometer with these swaps so actual mpg is a guess. My 67 with LS and my 2wd Blazer with LS gets MUCH better MPG than my 69 with regular ole small block with 350 turbo, and has mucho more power.
If you do the swap yourself, get everything you need from the SAME DONOR vehicle. Dont be afraid of the drive by wire, its no problem, just get the pedal assembly and wire harness from the TAC (throttle actuator control). Take time to find the RIGHT donor, hear it run before its pulled out if at all possible. Dont be afraid to pay more for a better eng/trans combo. Bargains on LS parts dont always turn out to be the best buy. JMO
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie 1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts 1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e |
11-21-2013, 03:04 PM | #23 |
Re: 5.3 swap ?s
I'm amazed at how popular the LS swaps for these trucks are. I've had 2 LS cars and love the motors. Had an 02 Z06 with the LS6 and now have an 06 Z06 with the LS7. I seriously thought when I came here it'd be all about the big blocks.
2006 Z06 2013 Cruze |
11-21-2013, 07:17 PM | #24 |
Old member
Re: 5.3 swap ?s
When mine gets done I will be using the same gauges as now.
www.speedhut.com stuff. GPS speedometer is dead on. No problems with it at all in a years time that I have had it in the truck.
11-21-2013, 08:47 PM | #25 |
Re: 5.3 swap ?s
I stuffed a 5.3/4L60E combo into a 81' Firebird recently and ohhh so much fun. LS juice is addictive for sure.
I custom built the harness as I went along. The caveat for the drive by wire is the pigtail for the pedal assembly had to be lengthened out and the pedal assembly had to be modified to sit on the floor in a similar manner to the stock pedal. Most of the drive by wire setups use a separate module to interface the pedal inputs to the main ECM so plan a separate box to find a home for under the hood. Do not weld any where near the pedal assembly itself, they are really sensitive to static from a welder. If you have the dollars to spend I HIGHLY recommend quality tail shaft adapter to give both mechanical speedo output and the digital out put the ECM requires to operate. They allow for stock speedometers to be used and make the ECM happy. Oil pans are super easy to swap, just make sure to get the oil pick up tube as they may not interchange. It was time consuming but super easy, attention to detail. A good site for info was nastyZ28, there is a ton a engine mods going on over there. Good luck. 88Ironduke
Retired USAF - No rockets, no mortars, no bad guys shooting...No stress!!! My Build Thread: Project 72' Green http://67-72chevytrucks.com/vboard/s...d.php?t=587932 |
