Old 11-17-2013, 08:38 PM   #1
Bernie
Distributor Hold Down Clamp
I have an Edelbock 2101 manifold and a Mallory Unilit distributor. My hold down clamp for the distributor does not keep the distributor from moving. Does anyone who has this arrangement know of a particular clamp that works ?
Bernie
Bernie is offline   Reply With Quote
Old 11-17-2013, 08:45 PM   #2
bigmac73
bigmac73's Avatar
Re: Distributor Hold Down Clamp
do you have a pic? can you add a washer, or does the "fork section" not touch the shoulder on the dizzy?
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 11-17-2013, 08:56 PM   #3
Bernie
Here are the pictures. It looks like the clamp is the wrong shape. No matter how hard I screw it down it won't grip the distributor base.
Bernie
Old 11-17-2013, 09:03 PM   #4
swamp rat
swamp rat's Avatar
I think it has been over tightened to the point it won't grab probably need a new clamp.
Do you have a gasket under the distributor? It kinda looks like the distributor isn't centered on the hole properly although i know the distributor should have a shoulder that keeps it centered.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 11-17-2013, 09:09 PM   #5
Bernie
I do have a gasket. The manifold and the distributor are off the truck to fix a stripped thread in one of the holes that goes into the water jacket, so the distributor might not be centered. The clamp hasn't bent; it has ribs underneath to strengthen it and those are intact. I think that it must be the wrong sort of clamp. Is there more than one type ?
Bernie
Old 11-17-2013, 09:14 PM   #6
vectorit
What?
vectorit's Avatar
That clamp is one of those chromed pot metal pieces of junk.
If you flip it over, it will be cracked.
Get yourself an OE steel clamp from the junk pile somewhere.
Make sure you use a stud/nut to clamp it down, since the manifold is aluminum you don't want to risk damaging the threads.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 11-17-2013, 09:11 PM   #7
mgchevyparts
mgchevyparts's Avatar
A flat washer or two under the clamp will enable it to gain the leverage it's missing. Looks like one of those well engineered Chinese units
1957 CHEVY 1/2 TON SHORT BED
1940 FORD 1/2 TON SHORT BED
mgchevyparts is offline   Reply With Quote
