Old 11-17-2013, 10:32 PM   #1
marcsRX
68 C10 SWB
marcsRX's Avatar
15x8 5x5 Rallys
Needing some help guys. Looking at picking up Wheel Vintiques 37 15x8 5x5 w/a 4" backspacing for the front and 15x10 w/a 5" backspacing for the rear. I'd like to run spider style lug covers as well. The truck has 5 lug disc conversion from Early Classic on the front and a 5 lug rear end from a 72 on the rear w/drums.
Truck also has a 4/6 drop from ECE.
Wanting to know if these wheels will fit my truck, and if I can run spider lug/hub covers. Please halp
"How much physical pain do you go through on a daily basis that you can directly attribute to your lack of intelligence?" -R0bman
marcsRX is offline   Reply With Quote
Old 11-17-2013, 10:34 PM   #2
marcsRX
68 C10 SWB
marcsRX's Avatar
Re: 15x8 5x5 Rallys
Here are the 10"
http://www.summitracing.com/parts/wv...0505/overview/
Here are the 8"
http://www.summitracing.com/parts/wv...0504/overview/
Old 11-17-2013, 11:36 PM   #3
cool68
Re: 15x8 5x5 Rallys
a lot depends on what size tire that you are planning to run. did you do the rearend swap? if so, did you get the outside measurements to know how much wider the '72 is. have chrome version of ones you are planning to run on my lowered '68 C10.search here for info here, and elsewhere, on how properly measure clearances on your truck and find out tire height/width
cool68 is offline   Reply With Quote
Old 11-17-2013, 11:45 PM   #4
marcsRX
68 C10 SWB
marcsRX's Avatar
Re: 15x8 5x5 Rallys
Probably a 255 70 15 front and 275 70 15 rear...
Old 11-17-2013, 11:53 PM   #5
WIDESIDE72
WIDESIDE72's Avatar
Re: 15x8 5x5 Rallys
I running stock 15x8 rallys with 275 60 15, not sure of backspacing
WIDESIDE72 is offline   Reply With Quote
Old 11-18-2013, 01:39 PM   #6
Keith Seymore
Keith Seymore's Avatar
Re: 15x8 5x5 Rallys
If they are stock then they are zero offset (4" backspacing).
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 11-18-2013, 02:08 PM   #7
geezer#99
geezer#99's Avatar
Re: 15x8 5x5 Rallys
K
I disagree!
4" bs on a 8" wheel has 1/2 inch of offset.
A zero offset 8" wheel would have a bs of 4.5".
Old 11-18-2013, 03:03 PM   #8
Keith Seymore
Re: 15x8 5x5 Rallys
Originally Posted by geezer#99 View Post
I disagree!
What am I missing? Because of the width of the flange/turnout at the bead seat?
"Zero offset" would be in the middle of the wheel, by definition.
I'll do some measuring when I get home.
K
1979-1986
1986 - 2019
Old 11-18-2013, 12:03 AM   #9
marcsRX
68 C10 SWB
marcsRX's Avatar
Re: 15x8 5x5 Rallys
no such thing as stock rallys on anything before 73 I believe...
Old 11-18-2013, 12:05 AM   #10
WIDESIDE72
WIDESIDE72's Avatar
Re: 15x8 5x5 Rallys
They are stock as in made by GM, not aftermarket. I did not mean stock to the truck.
Old 11-18-2013, 12:13 AM   #11
marcsRX
68 C10 SWB
marcsRX's Avatar
Re: 15x8 5x5 Rallys
gotcha
Old 11-18-2013, 12:24 AM   #12
WIDESIDE72
WIDESIDE72's Avatar
Re: 15x8 5x5 Rallys
gotcha
Uh...yea
Old 11-18-2013, 12:39 AM   #13
PAWS 72
PAWS 72's Avatar
Re: 15x8 5x5 Rallys
Got a question? I thought that those were the car Rallys .
am I right or wrong?
PAWS 72 is offline   Reply With Quote
Old 11-18-2013, 12:43 AM   #14
geezer#99
geezer#99's Avatar
Re: 15x8 5x5 Rallys
A quick search shows you're right.
http://www.summitracing.com/int/part...0504/overview/
Old 11-18-2013, 01:42 PM   #15
Keith Seymore
Re: 15x8 5x5 Rallys
These are Corvette (style) rally wheels:
Available on Corvette, Chevelle, Nova, Camaro, Corvair, Impala and probably some others I'm forgetting. Production wheels had bumps in the spider to retain the various center caps. Sizes range from 14x6 to 15x8, depending on application.
These are truck wheels, first available in 1975 and through the end of the C/K/R/V product cycle. 15x7 for vans, 15x8 for pickup and utility.
K
1979-1986
1986 - 2019
Old 11-18-2013, 12:15 AM   #16
geezer#99
geezer#99's Avatar
Re: 15x8 5x5 Rallys
If you want to figure out what fits, here's a link.
http://www.carcraft.com/techarticles...t/viewall.html
Old 11-18-2013, 12:54 AM   #17
marcsRX
68 C10 SWB
marcsRX's Avatar
Re: 15x8 5x5 Rallys
What? They are truck wheels... Says so right in the name.
Wheel Vintiques 37 Series Silver 1971 & Up Pickup Rallye Silver Wheels
Additional Information
Get the right wheel for your vintage GM truck from Wheel Vintiques. Perfect for everything from everyday street drivers to full-blown restorations, these wheels are sure to make your truck stand out from the crowd. Made from steel, these durable wheels feature an OEM-style silver finish, and precise machining so all of your factory accessories will fit.
Old 11-18-2013, 01:22 AM   #18
geezer#99
geezer#99's Avatar
Re: 15x8 5x5 Rallys
Yup it does but it doesn't say OE (original equipment) style wheels like these series 42's.
Old 11-18-2013, 03:21 AM   #19
marcsRX
68 C10 SWB
marcsRX's Avatar
Re: 15x8 5x5 Rallys
Hmm I think those are 73 model year and up because there are no OE rallys prior. Thats why the ones I listed can not be "OE". Also the cut outs on the ones in ur link are different, like van rally wheels.
Old 11-18-2013, 03:49 AM   #20
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: 15x8 5x5 Rallys
With those tire sizes and back spacing you should have plenty of clearance...I have 8" rally's with 275/60/15's front and rear...The rally's I have are 4-1/2" back spacing and rubbed the front fenders in turns and bumps with the 4-1/2" drop up front so I raised it an inch...No more rubbing...I installed a front sway bar as well. Plenty of clearance out back. I used 2-1/2" drop spindles with 2" drop springs up front and the 60's wouldnt clear so reinstalled the factory coils with 1/2 coil cut off...The factory coils are a bit stiffer than the drop coils which is a plus in the turns...IMO
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 11-18-2013, 01:41 PM   #21
Keith Seymore
Re: 15x8 5x5 Rallys
Wow. Those look really nice.
K
1979-1986
1986 - 2019
Old 11-18-2013, 03:56 AM   #22
marcsRX
68 C10 SWB
marcsRX's Avatar
Re: 15x8 5x5 Rallys
I think I'm going to revise this. Now thinking same wheel 7" wide powder coated back. For tires running cooper trendsetter es narrow white walls in 235/75/15. Plus the spider chrome lug covers.
Old 11-18-2013, 01:15 PM   #23
cool68
Re: 15x8 5x5 Rallys
whatever you decide on run taller tires in the rear - looks much better.
Old 11-18-2013, 03:23 PM   #24
geezer#99
geezer#99's Avatar
Re: 15x8 5x5 Rallys
Typical wheels are called say 8" wide which is the measurement from bead to bead. However the actual width is 9" which is width from wheel lip to wheel lip. BS is measured from wheel lip to mounting surface.
It would be nice if bs was measured from bead to mounting surface but it's difficult to measure accurately.
So an 8" wheel is actually 9" wide minus the bs of 4" leaves 5". Centreline of wheel is 4.5 inches. 5"-4.5" equals 1/2 inch of offset.
This link might help.
http://www.rimsntires.com/specs.jsp
Old 11-18-2013, 04:13 PM   #25
Keith Seymore
Re: 15x8 5x5 Rallys
ok; Yep - I agree.
I have both truck wheels and Corvette wheels readily available. I can do some measuring (once the power comes back on...).
K
1979-1986
1986 - 2019
