Old 11-18-2013, 10:37 AM   #1
Ol' Drippy
Help! Door striker nut fell out of B pillar
I was removing the door striker in the front passenger side door of my 78 suburban and the plate it screws into and allows for adjustmant just fell as soon as I go the bolt out. Anybody know how I can fix this? I am not even sure if the plate is still in the B pillar at the bottom or if it fell onto the ground.
Ol' Drippy is offline   Reply With Quote
Old 11-18-2013, 05:35 PM   #2
crazeetxn
crazeetxn's Avatar
Re: Help! Door striker nut fell out of B pillar
If it fell out on the ground, is there an access panel anywhere? Can't imagine them putting something together with have access somewhere.
1st - '68 long bed
2nd - '81 SWB
Now - '86 SWB, Edelbrock 1406/stock 350/700r4
crazeetxn is offline   Reply With Quote
Old 11-18-2013, 08:48 PM   #3
willett
Another Day, Another Dollar
willett's Avatar
It's probably floating in your rocker/cab corner now. Whatever is in the corner behind the seat should come out. I think there's a speaker there?
Anyways a telescopic magnet is going to be your friend...
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 11-18-2013, 11:25 PM   #4
baclay9
That backing plate is not attached, that is what allows adjustment. Pull the speaker bracket and it should be behind there somewhere.
baclay9 is offline   Reply With Quote
Old 11-18-2013, 11:54 PM   #5
joe231
joe231's Avatar
There is an access panel behind the b-pillar trim.
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 11-19-2013, 12:29 AM   #6
mrolds88
As far as a fix, once you have regathered your parts, this is what I would do. Take the plate that held the nut in place and hold it up on the door side of the jamb, marking the outline of it. drill several holes I areas that you can later weld or rivet. Using a unraveled paper clip, hook the paper clip in the plate and nut, then tie a string or piece of wire that you fed down through the hole in the B pillar. Then simply pull it up and through the hole. If you need to weld, the paper clip will take what you need it to. Once you finish the repair, then just use a pair of pliers to remove the paper clip.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 11-19-2013, 08:42 AM   #7
Ol' Drippy
Thanks for the tips everyone, this is a suburban so I am not sure if I have an access panel anywhere on the B pillar but I will look. These things aren't supposed to fall out are they? In my other GM vehicles something is holding that plate to the B pillar so this doesn't happen, now I am afraid to pull the striker bolt on the other 3 doors.
Old 11-19-2013, 09:07 AM   #8
Greenlee
Greenlee's Avatar
They are loose. On the trucks you can reach back there and hold it. I can't remember if there is something different about the Suburbans. You probably have to remove some plastic trim to get access.
Greenlee is offline   Reply With Quote
Old 11-19-2013, 03:30 PM   #9
thinair
thinair
thinair's Avatar
Been awhile since I've been inside one, but take the trim panel off and if I remember right, you will have to pull the seat belt mech. also and I bet that it is right there.
thinair is offline   Reply With Quote
Old 11-19-2013, 03:33 PM   #10
mrolds88
There is an access hole just above the floor.
93 K2500 xcab 6.5TD
Old 11-25-2013, 03:00 PM   #11
Ol' Drippy
Thanks again for the help everyone, I pulled my B pillar trim back and there were a couple of access holes. I was able to retrieve the plate with a magnet using the lower hole and reinstall the plate using the upper hole, it sure is nice to have a door that actually closes again.
