11-18-2013, 12:29 PM | #1 |
How accurate is the oil pressure gauge?
I had a mechanical oil pressure gauge and it seems to read kind of high. My '73 runs fine and I just put it off that maybe the gauge was not working properly. Is this a common occurrence and is there a way to check if it is the gauge or something more serious?
1973 Chevy K20 |
11-18-2013, 12:46 PM | #2 |
Re: How accurate is the oil pressure gauge?
What do you consider kind of high?
1st - '68 long bed 2nd - '81 SWB Now - '86 SWB, Edelbrock 1406/stock 350/700r4 |
11-18-2013, 12:55 PM | #3 |
It seems to run in the middle but then when I rev it she will max out.
1973 Chevy K20 |
11-18-2013, 01:45 PM | #4 |
Another Day, Another Dollar
What oil you running?
Engine cold or hot? Which motor?
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box "its hip to be square" |
11-18-2013, 01:45 PM | #5 |
It is not accurate at all. Its a pass/fail indicator more than anything. Could be that the guage is just worn out. I can't think of anything that would cause high oil pressure. Get a good quality pressure guage set and screw into one of the ports and measure what you're actually getting for pressure, then replace the dash gauge as needed. 10lbs/1000rpm is the rule of thumb, up to about 40 or 50.
11-18-2013, 02:22 PM | #6 |
Yeah, thats what I figured. I pulled hte gauge out to look at the back and it looked all old and worn out.
1973 Chevy K20 |
11-18-2013, 04:58 PM | #7 |
It's going to be different for every truck/gauge/engine/oil/miles out there. Pass/fail from prior experience is about right.
- 1981 Sierra 454, NV4500 swap - 2006 Z06, 25k miles - 1973 Nova - Project CarNova Virus on Youtube |
11-18-2013, 05:33 PM | #8 |
So basically it sounds like you are all saying that if it is off or runs high then it probably is not the vehicle and more likely the sensor.
1973 Chevy K20 |
11-18-2013, 05:55 PM | #9 | ||
And I have to disagree with some of the others here ... I've found the factory mechanical oil pressure gauges to be quite accurate. In fact, the mechanism inside is basically the same design as you'd find in pretty much any mechanical pressure gauge (factory or aftermarket). They can get worn out and/or dirty but that usually causes the needle to catch or stick instead of reading high. Quote:
11-18-2013, 05:59 PM | #10 |
The engine has been beefed up a bit from stock so it may be a high volume oil pressure pump. Is there a way to verify this?
1973 Chevy K20 |
11-18-2013, 06:44 PM | #11 | |
It's not uncommon for a high volume/pressure pump to get the oil pressure up around 70 to 80 psi. Especially with relatively thick oil and/or an engine that isn't warmed all the way up to operating temp. If your engine is building up over 60 psi and you want to maintain a stock looking instrument panel, there were some factory 80 psi mechanical oil pressure gauges that are a direct fit into a 73 - 77 cluster. They were typically found in medium duty trucks. |
11-18-2013, 06:53 PM | #12 | |
1973 Chevy K20 |
